    House I'm Working On
    4 Posts 3 Posters 620 Views 3 Watching
    • m.wendtM Offline
      m.wendt
      I'm really looking for suggestions here people. I have some things figured out such as the guest house is the bit to the right, and the pool house could double as a second guest house (it is located partially underground to the left of the pool area). The main House is a tri-split... still working on it but two levels and then a third is the basement of where the guest house is, but the walk out into the bay to the far right... yeah: work in progress.
      So also another thing I should point out is the .50 CAL mounts up front is just a play into the concept of this house being located on a remote island, and whenever I do island projects I install elaborate defense systems, so there are already configured to drop down below the grass there and have nice grass panels that slide atop, heh heh. Okay so I also did a VERY Quick render (no global even, just some lighting)
      So yes. I'm planning on putting up some wind turbines on the Western shore later, but I NEED some suggestions please. Anything. Really. Thank you
        mrnoonie
        hi, nice house, id suggest adding theese plugings to your sketchup.
        instant roof- save a hell of alot of time, offers different looks and allowys you to creat your own roof style.
        http://www.valiarchitects.com/sketchup_scripts/instant-roof
        instant road- this aslo will save you alot of time, and offes you a realstic looking road, wich cold be used fora drive.
        http://www.valiarchitects.com/sketchup_scripts/instant-road
        instant site grader i havnt actually used this plugin, but looks cool. allowys you to add hills around your house.
        http://www.valiarchitects.com/sketchup_scripts/instant-site-grader
        anyway, you can get them at this link: http://www.valiarchitects.com/sketchup_scripts
        HAPY SKETCHING πŸ˜„
        Kieran Berry AKA MrNoonie ---- http://mrnoonieskp.limewebs.com/index.html
        • m.wendtM Offline
          m.wendt
          Thanks! I'll try those in future models for sure... maybe even this one for the path that encircles the island, cuts through the woods etc-- and you don't see any of that because I'm designing the house first. Thanks again. Anyone else have some ideas??
          • Bryan KB Offline
            Great link mrnoonie. Thank you.
