    Looking for Victorian Column
    8 Posts 5 Posters 1.8k Views 5 Watching
      andre51
      I'm Looking for a cast alu Victorian column to use in a wine cellar. The pic attached shows the actual sample from the supplier, 2875mm high. If anyone can help with a similar column that I can adjust it will be great.
      Regards Andre
      • FrederikF Offline
        Frederik
        Have you checked the 3D Warehouse...??
        You can also find some nice models at FormFonts...
        Cheers
        Kim Frederik
        • stefanqS Offline
          stefanq
          I hope this is similar enough for you. Found it on the web as 3ds model, converted to su model. It's not perfect, I used cleanup plug-in from Thomas, but as you see it renders pretty fine.
          Cheers!
          Colum321.rar
          • BoxB Offline
            I knocked this up in about an hour as an interpretation of your drawing.
            I kept it as simple as possible, with only Bezier curve and Extrude by rails plug-ins.
            Hope it helps.
            Column Victorian.skp
              andre51
              Hey thanks stefanq & box,
              Both columns are really great! Will post pics of the completed work.
              Regards
              Andre
                resistor
                Pls share a method how you converted.
                • stefanqS Offline
                  stefanq
                  Resistor,it's very simple, just import a 3ds model, select the model and use the cleanup tool. This is the link for this wonderful plug-in. Watch the tutorials!
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=22920&p=193587&hilit=%5BPlugin%5D#p193587
                    resistor
                    Thank you, stefanq
