    Commit working like undo command
    4 Posts 3 Posters 408 Views 3 Watching
    • B
      bizello
      I trying to use commit to do some like "undo" command. I´ve found something in the net and one script worked, but others...
      The code below works, you can activate only a "commit line" and the face is erased like you want, full control.
      def desenha1
      modelo = Sketchup.active_model
      entities = modelo.active_entities
      pt = []
      pt[0] = [0,0,0]
      pt[1] = [5,0,0]
      pt[2] = [5,5,0]
      pt[3] = [0,5,0]
      abertura = entities.add_face pt
      def desenha2
      pt = []
      pt[0] = [0,6,0]
      pt[1] = [5,6,0]
      pt[2] = [5,10,0]
      pt[3] = [0,10,0]
      def desenha3
      pt = []
      pt[0] = [6,0,0]
      pt[1] = [10,0,0]
      pt[2] = [10,4,0]
      pt[3] = [6,4,0]
      #Sketchup.active_model.start_operation("Undo")
      desenha1
      desenha2
      desenha3
      resposta = UI.messagebox "Erase face?", MB_YESNO
      if resposta == 6 then
      Sketchup.active_model.commit_operation(a)
      else
      UI.messagebox "So stay."
      But I have a part of the another code that doesn't work, I think you don't need all the code, so I'm sending the part with "commit" don't working, the code below:
      model = Sketchup.active_model
      Sketchup.active_model.start_operation("undo")
      entities = model.active_entities
      abertura = entities.add_face ptabs
      rayt=modelo.raytest(ptabs[0], abertura .normal.reverse)
      ptabs_rev=rayt[0]
      espess=ptabs[0].distance(ptabs_rev)
      abertura.pushpull(-espess)
      abeyesno = UI.messagebox "A posição da abertura na parede está correta?
      Proceder com o cadastro no Banco de Dados?", MB_YESNO
      if abeyesno == 6 then #yes
         cadaberturas(ptabs, espess, cod_arq_atual[0], cod_arq_atual[1], localiza)
        else
         Sketchup.active_model.commit_operation(abertura)
      I dont' know why the second code doesn't work. I can't see what is wrong.
      If you help me, very thanks.
      Sérgio.
      PS. I need to answer like I solved the my another topis called "edges, angle and rectangle triangle". I'll to write all the problem and describe my solution.
      Sérgio A.Bizello
      • Dan RathbunD
        Dan Rathbun
        Do not name each operation with the same string "Undo"...
        give each a unique name "Draw Face 1", "Draw Face 2", etc.
        It's best to wrap each operation in a begin ... rescue ... end block and have an abort_operation call in the rescue clause. (methods are also begin .. rescue .. end blocks, where the def *methodname* takes the place of the begin keyword.)
        begin
          modelo.start_operation("Draw Wall 1")
          # ... draw entities code ...
          modelo.commit_operation
          msg = "A posição da abertura na parede está correta?\n"
          msg<< "Proceder com o cadastro no Banco de Dados?"
          abeyesno = UI.messagebox( msg, MB_YESNO )
          else
            Sketchup.send_action("editUndo;")
        rescue
          modelo.abort_operation
          UI.messagebox("Error Adding Enities!")
        Edit: corrected newline character in messagebox string.
        commit_operation and abort_operation do not have arguments:
        modelo.method(:commit_operation).arity
        modelo.method(:abort_operation).arity
        I'm not here much anymore.
        • B
          bizello
          Hi Dan,
          Thank you. Its works now.
          I think understand how using commit.
          Thanks to show how you do your messages in a script. I liked.
          I had some asks about send_action and abort but I saw how they works.
          So, I edit this post.
          Thank you Dan.
          SérgioBizello
          Sérgio A.Bizello
          • thomthomT
            Note that start_operation cannot be nested. Doing a new start_operation after another will commit the first.
