    Glass World
    8 Posts 5 Posters 922 Views 5 Watching
    • charly2008C
      charly2008
      here is a little exercise with the world as a glass ball.
      Charly
      • mitcorbM
        mitcorb
        That's really neat. I assume the continents are projected textures? Did you use Kerkythea glass texture? What does the backside of Africa look like? (this ought to generate some interesting replies)
        • charly2008C
          charly2008
          Hi Mitcorb,
          I took a photo of a globe projection (I do not know how this projection is called) and made it into a transparent PNG and placed it on a sphere (not projected). Yes the Glas is from Kerkythea.
          Charly
          • mitcorbM
            mitcorb
            Do you mean you used an actual camera, or did you sample an image? Either way, it's a nice exercise, and the final image is well done.
            I am only now experimenting with Kerkythea. I am handicapped by elderly equipment, and one of the things that has held me back is the fact that no matter what equipment you have, it still takes time to see the results as opposed to "toon shading" directly in Sketchup.
            • Bryan KB
              Well done!
              Also, thank you for posting the texture.
              • boofredlayB
                boofredlay
                Sweet!
                • W
                  watkins
                  Wiki has a fairly detailed discussion on map projections:
                  http://en.wikipedia.org/wiki/Map_projection
                  There is also this very nice website on a cornucopia of subjects (check out the discussion on aspect ratios):
                  404 Not Found
                  (www.quadibloc.com)
                  Regards,
                  Bob
                  • charly2008C
                    charly2008
                    Hi Watkins,
                    thanks for these links. Could be a cylindrical projection. If anyone is interested, the model(12MB) can be downloaded at:
                    http://www.speedshare.org/download.php?id=80BFB1D811
                    Charly
                    2012
                    2012
