[Plugin] Instant Roof
Instant Roof - the easiest way to make roofs!
Thanks to the SketchUcation community Instant Roof is available in French(Didier Bur), Spanish(Diego Rodriguez), and Portuguese(Marcelo Pavan).
New User Contributed Styles Library is now available at our website.
A "Styles Library" is now available for users to post their own roof styles for others to download and use. I have just added two styles "Thatched Roof" and "Sea Lodge". The Styles Library can be found at Miscellaneous Downloads.http://www.valiarchitects.com/misc_downloads
Instructions on how to create, export and import styles to Instant Roof is available in pdf format.http://www.valiarchitects.com/sites/default/files/tutorials/pdf/Roof-Styles.pdf
We look forward to seeing your roof creations or just download styles and post a user rating for that style.What Instant Roof can do:
* Create a complex roof in seconds - just select faces and edges; then run Instant Roof.
* Hip, gable, shed, dutch-gable, mansard, plantation, gambrel, open-trellis, combined, more...
* Eave types: boxed-in, exposed, soffited
* Hips and rafters with customizable ends
* Fascia, fascia-trim, ridge and hip tiles, shingles, or sheet-metal
* Complete mission tile or standing-seam roof
* Use default roof styles - or create your own
* Export and Import user defined roof styles
* Choose any unit type supported by Sketchup: Metric- angles for slope or Feet/ inches - ratio for slope
* Upgrade to Pro version for more roof slopes (The free version will only create the following roof slopes: 1/8:12 (0.6 degrees) ; 2:12 (9.5 degrees) ; 6:12 (26.6 degrees) ; 16:12 (53 degrees) or 24:12 (63 degrees).Plugin Author: Vali Architects (Chuck Vali)
Plugin Website: http://www.valiarchitects.com/sketchup_scripts -
Tried this out on a gambrel and it only produced the skins. no rafters or truss system. so basically a fake roof skin of no value to me.
Thank you very much!
This is very weird, I just went to your site after reading an old issue of 3D World, to check out this plugin! I downloaded the free versions of this and the other two scripts you have there and was wondering to myself-"This is so cool and useful! Why hasn't anyone mentioned this before!?!" Ha,now I find this post here!!
I only had time to play around with this for a few minutes so far- BUT- definitely well thought out and very useful.
Also VERY generous to offer a free version!
Thank you! -
If only Id found this plug in BEFORE i went through all the trouble of making my own roof! Great program. Highly reccomend, save yourself...AND ...customer service is fast and all on the up-n-up
Register LoginAdvertisement
