    Need Help
    7 Posts 4 Posters 562 Views 4 Watching
      amiris
      Hello everybody.
      I'm looking for a plug-in that gives the angle between two selected plans.
      I have already found such : ( plane_angle) but it seem not to work on the SU 7.
      THANKS
      Amir β˜€
        DOD3R
        I would go for some geometric construction via intersection with third plane and than measure it with protractor. At least that is, what I do when needed. Finding and using some plugins will be more time consuming, but more efficient if repeated.
        • Didier BurD Offline
          Didier Bur
          Wait a minute (a day πŸ˜• ).
          The formula is quite simple.
          I'll code it asap and post it here.
          EDIT: 15mn later... πŸ˜„
          Unzip it in your Plugins folder.
          Select 2 faces, open the ruby console and type 'angleBetweenPlanes' This will output the 2 planes equations and the angle in radians and degrees.
          Hope that helps,
          angleBetweenPlanes.zip
          DB
            amiris
            Hello there.
            Thanks so much for your quick response for my first post here. 😲
            here is more nuances for the situation of the angle requested between 2 plans:
            (see attached screen shut)
            the angle requsted here is "a" .
            Dear Didier, your plug in works very good but gives the complete angle which is "b".
            sure i can do 180 - b = a (or use the protractor) but it is repatative action and
            using a plug in save lot of time. also if the angle is close to 90 degree i have to double check it by using the protractor (because it's hard to distinguish by eye).
            generaly, it would be great for a plug in to distinguish between the requested angle (a , b , or c) . maybe i'm asking too much πŸ˜„ .
            the plane_angle.rb (by kaidu) gives a similar result by right clicking on a common edge of two connected plans.
            Didier, thanks sooo much for all what you contribute .
              Didier Bur
              Maybe my dim_angle script will do the trick ?
              -> Creates an angular dimension with arc and text in a group.
              Here: http://rhin.crai.archi.fr/rld/plugin_details.php?id=110
              DB
                amiris
                Didier.
                exactly what i need.
                bless
                Amir
                • V Offline
                  vidy
                  Dear Didier,
                  Thanks for this sweet plug-ins, never realized this until i need to put some angular measure on my drawing...
                  regards,
                  still so much to learn..
