    Google toolbar: get position
    4 Posts 2 Posters 423 Views 2 Watching
    • bomastudioB
      bomastudio
      Hi all, do you know how can I call the get position (the 1st command in Google Toolbar) via API?
      I looked around and found that SU5 had some script for manage the Google Earth input/ouput.
      • Dan RathbunD
        Dan Rathbun
        Answer posted in this topic:
        [Code] Sketchup.send_action() : Arguments to
        I'm not here much anymore.
        • bomastudioB
          bomastudio
          that's ok. It works fine.
          I posted the question in a bad way. Excuse me. I would know what SU does when this command is sent.... I need to "grab" the calling to deviate it, as html, to a windows (like a webdialog). i need this because under Linux+wine the Toolbar doesn't work at all. So I think to build, thought wxSU, a html viewer to wich I will send the output of the command .... provided that it is possible.... 😍 😍
          • Dan RathbunD
            Dan Rathbun
            No.. you cannot intercept the call. It is hard-coded into the Sketchup application on the C++ side, not on the Ruby side.
