    Loop.convex? question
    5 Posts 3 Posters 579 Views 3 Watching
    • DavidBoulderD
      DavidBoulder
      I was experimenting with loop.convex? and found that extra co-linear points make a surface fail this test. As a result for example if I had a rectangle that I extrude it up, and then draw a rectangle on the bottom edge of one of the side surfaces that represents a door; the floor which would have otherwise passed the convex test, now fails it. I made a variation on the sample code in the API documentation to demonstrate it. Does anyone know an easy way to catch these cases so they don't fail?
       depth = 100
       width = 100
       model = Sketchup.active_model
       entities = model.active_entities
       pts = []
       pts[0] = [0, 0, 0]
       pts[1] = [width, 0, 0]
       pts[2] = [width, depth, 0]
       pts[3] = [0, depth, 0]
       # Add the face to the entities in the model
       face = entities.add_face pts
       loop = face.outer_loop
       status = loop.convex?
       if (status)
         UI.messagebox "Loop is Convex"
       else
         UI.messagebox "Loop is not Convex"
       ptsB = []
       ptsB[0] = [200+0, 0, 0]
       ptsB[1] = [200+width/2, 0, 0]
       ptsB[2] = [200+width, 0, 0]
       ptsB[3] = [200+width, depth, 0]
       ptsB[4] = [200+0, depth, 0]
       face = entities.add_face ptsB
       if (status)
       else
      David Goldwasser
      OpenStudio Developer
      • DavidBoulderD
        DavidBoulder
        Kind of a related question. I have a source data file that has clean versions of for example the floor that has only 4 verticies vs 6 (2 extra for the door). An alternative approach is to bring in those verticies, and do a loop.convex? test on them. But it appears I have to make a face before I can make a loop? Any way to do that without actually drawing a face. Otherwise, I can draw and erase a face, but seems like it would slow things down.
        David Goldwasser
        • K
          kyyu
          You could get the vertices and get rid of the ones that form coliner edges. Make a new temporary face and go from there. Not pretty, but works. Maybe some has a better idea?
          Oh, anyone got a simple/elequent way of getting the new vertices set, instead of what I did?
          depth = 100
          width = 100
          ptsB = []
          # Only keep non-colinear vertices
          v = []
          ver = face.outer_loop.vertices
          n = (ver.length - 2)
              v1 = ver[0].position
              v2 = ver[1].position
              u1 = [(v2.x - v1.x), (v2.y - v1.y), (v2.z - v1.z)].normalize!
              u1_saved = u1
          for i in 1..n do
              v1 = ver[i].position
              v2 = ver[i+1].position
              u2 = [(v2.x - v1.x), (v2.y - v1.y), (v2.z - v1.z)].normalize!
              if u1 != u2 then v.push ver[i] end
              u1 = u2
              v1 = ver[(ver.length - 1)].position
              v2 = ver[0].position
              if u1 != u2 then v.push ver[(ver.length - 1)] end
              u1 = u2
          if u1 != u1_saved then v.push ver[0] end
          # make new face & loop
          group = entities.add_group
          face2 = group.entities.add_face v
          loop = face2.outer_loop
          if (status)
          else
          group.erase!
          • thomthomT
            You could do your own convex function.
            I got a method for getting only the corner vertices of a face:
            http://www.thomthom.net/software/sketchup/tt_lib2/doc/TT/Face.html#corners-class_method
            (Click View Source)
            In my old TT_Lib1 library I had a method for getting the convext shape of a set of points in 2d space. http://forums.sketchucation.com/viewtopic.php?f=180&t=34306&start=15#p302805
            Didier made one for 3d I think. (See later that thread)
            Maybe you can cobble together something from this to your own convex? method?
            • DavidBoulderD
              DavidBoulder
              Thanks for the feedback. The data file that is drawing my geometry in the first place already has a smaller list of verticies that is clean. So I guess that is the best option, going back to that, drawing a temporary face to test, and throwing it away. I don't know how much of a performance hit that will be over testing an existing face. But what I can do is pre-test with the existing face, and then only create a temporary face to test on the ones that initially fail.
              David
              Below is the code I ended up with. My SketchUp objects are drawn from data in an external file. I could have drawn temporary faces for convex test for every surface but decided to do the initial test off of the existing SketchUp faces, and then do a second test on faces that fail the convex test to confirm that they really are non-convex. This second test goes back to the data file, draws a temporary surface, tests it, and throws it away. The data file is already fee of un-necessary stray points.
                             if @hash['NON_CONVEX_SURFACES']
                             face = interior_partition_surfaces[index].entity
                               # if face is convex skip over it
                               if status
                                 next
                               else
                                 # failed first convex test, run second one
                                 pointstemp = interior_partition_surfaces[index].model_object_polygon.points
                                 facetemp = entities.add_face pointstemp
                                 loop2 = facetemp.outer_loop
                                 status2 = loop2.convex?
                                 # erase facetemp
                                 facetempall = facetemp.all_connected
                                 entities.erase_entities facetempall
                                 if status2
                                   # next statement skips the rest of this if face is convex
                                   next
              David Goldwasser
