    What means "class" here?
    11 Posts 4 Posters 798 Views 4 Watching
    • honoluludesktopH Offline
      honoluludesktop
      What's the difference if any?
      ss = model.selection
      ss.each do |e|
        if e.class == Sketchup;;ComponentInstance
          #other stuff
      ss.each do |e|
        if e.is_a? Sketchup;;ComponentInstance
          #other stuff
        ebd
      tt, or anyone else, how do I get color in my code? "Font colour" doesn't seem to do it.
        is_a? checks for inheritance as well.
        <span class="syntaxdefault"><br />class Foo<br />end<br /><br />class Bar </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> Foo<br />end<br /><br />f </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Foo</span><span class="syntaxkeyword">.new<br /></span><span class="syntaxdefault">b </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Bar</span><span class="syntaxkeyword">.new<br /><br /></span><span class="syntaxdefault">f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">class </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> Foo </span><span class="syntaxcomment"># => true<br /></span><span class="syntaxdefault">b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">class </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> Foo </span><span class="syntaxcomment"># => false<br /></span><span class="syntaxdefault">b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">class </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> Bar </span><span class="syntaxcomment"># => true<br /><br /></span><span class="syntaxdefault">f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Foo</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># => true<br /></span><span class="syntaxdefault">b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Foo</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># => true<br /></span><span class="syntaxdefault">b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Bar</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># => true<br /></span><span class="syntaxdefault"> </span>
          honoluludesktop
          Had to look up "inheritance" to get it. Thanks.
          • Dan RathbunD Offline
            Dan Rathbun
            We are cheating, the color lexer for php is built-in to phpBB, so we are change the 1st code tag:
            It does not properly color Ruby but ... we are impatient. 😛
            [code=php]
            I'm not here much anymore.
              @dan rathbun said:
              This is a wee bit slower because on the C side:[list]
              Results seems negligible though: http://forums.sketchucation.com/viewtopic.php?f=323&t=19576&st=0&sk=t&sd=a&start=15#p166698
              The difference between the test of the same method differs just as must as the difference between .is_a? and .class.
              Maybe performance is more noticeable if the objects has higher levels of inheritance, but there seem to be no practical savings in .class ==
                Dan Rathbun
                Well ... compiled C is really fast!! We are talking about milliseconds here.
                Nice .. but. How many times did you run the tests ?
                I've found it really takes a minimum of 8 times (saving the results, then taking the mean of the total.)
                I don't see that in the numbers.. I see that using the alias .is_a? takes a wee bit more time that calling .kind_of? directly.
                I would agree with 'higher levels' as the C while loop must eat time...
                The main reason I do it (and encourage it,) is for readability. If your testing for class equality, I use the == it's only 2 more characters (as .class and .is_a? both have the same number of characters.)
                BUT.. your reply just made me realize something I missed.
                object.class==ClassName is actually calling 2 Ruby methods, whereas:
                object.kind_of? ClassName is only calling 1 Ruby method, so ....
                in long loops, kind_of?() is bound to be faster(the fastest of the three.)
                  Dan Rathbun
                  .is_a?() is a bit misleading, it is an alias for .kind_of?() (which I prefer to use instead.)
                  if e.class == Sketchup::ComponentInstance
                  This is faster than .is_a?() or kind_of?() because:
                  EDIT: not so.. I forgot that both .class() AND .==() are both method calls, and kind_of?() is only one call so it's faster. (see posts further down.)
                  • class Class inherits it's ==() method from class Object, via class Module. The Object.==() method, is implemented in C, as a simple if statement:
                  static VALUE
                  rb_obj_equal(obj1, obj2)
                      VALUE obj1, obj2;
                      if (obj1 == obj2) return Qtrue;
                      return Qfalse;
                  if e.is_a? Sketchup::ComponentInstance
                  • it has to go through a switch statement for typechecking, then through a while loop
                  VALUE
                  rb_obj_is_kind_of(obj, c)
                      VALUE obj, c;
                      VALUE cl = CLASS_OF(obj);
                      switch (TYPE(c)) {
                        case T_MODULE;
                        case T_CLASS;
                        case T_ICLASS;
                          break;
                        default;
                          rb_raise(rb_eTypeError, "class or module required");
                      while (cl) {
                          if (cl == c || RCLASS(cl)->m_tbl == RCLASS(c)->m_tbl)
                              return Qtrue;
                          cl = RCLASS(cl)->super;
                      return Qfalse;
                  • Since all Sketchup's Drawingelement subclasses have NO subclasses of their own, using .is_a?() or .kind_of?() is pointless, IF the argument is the Drawingelement subclass your testing for.
                  So when should you use .is_a?() or .kind_of?() ??
                  EDIT: Always when iterating, especially the model or other large collections, use kind_of? or is_a? (see posts further down.)
                  When iterating the objects in a model, if you are only interested in those "kind of" objects that are drawing elements, and you wish to ignore such objects as layers, views, pages, shadowinfo, etc.; then you would use:
                  if e.kind_of?( Sketchup::Drawingelement )
                  which returns true only for objetcs like faces, edges, curves, etc.
                    I ran them on models I had, you see the model status under the data results.
                    First test:
                    ` is_a? - 0.89c
                    kind_of? - 0.782c
                    class - 0.875c`
                    Second test:
                    ` is_a? - 16.297c
                    kind_of? - 16.141c
                    class - 18.703c`
                    The odd bit is the .class call being slower in the second test. I credit the difference to other system variations.
                    Since is_a? and kind_of? are aliases they should be the same. (If we tested spherical chickens in vacuum. 😉 )
                    Yea - I didn't do that.
                      Dan Rathbun
                      Nope ... not variables.
                      Its actually *object*.class().==( *argument* )
                      so ....
                        That's a good point. I still keep forgetting that == as method .==.
                          david.
                          Don't forget instance_of? when only looking for a specific class without regard to inheritance. As in
                          <span class="syntaxdefault"><br />ss </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />ss</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each do </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">  if e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instance_of</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance<br />    </span><span class="syntaxcomment">#other stuff<br /></span><span class="syntaxdefault">  end<br />end</span>
