    Can it be possible,export whole pages into dwg in one action
    23 Posts 8 Posters 2.1k Views 8 Watching
    • ladcweiL
      ladcwei
      Hello everyone!
      I have one problem to solve ,can it be possible to export whole pages into dwgs in one action?Because I work with such workflow: 1.Modeling in Su 2.make pages of all view(plans,sections) 3.export all pages to dwg files 4.xref those files in a new file which will be used to do dimensions and labels.
      So if I would export whole pages into dwgs in one action,that would be a easy trip.Maybe a plugin is needed,has someone know it?
      • J
        Jim
        I do not know of a plugin that already exists, but it is possible for a plugin to go through each Scene and export a .dwg for each one.
        • KrisidiousK
          Krisidious
          I think you should include layout in your work flow... it has a powerful dwg export function.
          it takes the materials in sketchup models and converts them to hatch pattens and raster images and allows you vector or raster exports or combinations of either.
          my work flow is
          sketch on paper,
          import scans to sketchup,
          model structure in 3D,
          export to layout,
          create sheets for each scene,
          export to autocad,
          dimension, labels and notes,
          export to pdf.
          By: Kristoff Rand
          • ladcweiL
            ladcwei
            Thanks a lot ,I found that's really a good idea ,however,how to export dwg files without hidden lines?
            • honoluludesktopH
              honoluludesktop
              What did you find?
              • ladcweiL
                ladcwei
                I found LO could export dwg files well,but I still found all the hidden lines still be there,and I have to remove them by myself πŸ˜‰
                • Didier BurD
                  Didier Bur
                  My plugin ADO is for you (exports all your scenes to JPG's, pDF's, DWG's and so on).
                  Go to Ruby Library Depot (actually down) and search for ADO plugin in the Files-Misc section.
                  It's a very old one, so please tell me if it works on SU7 or SU8 πŸ˜‰
                  Regards,
                  DB
                  • honoluludesktopH
                    honoluludesktop
                    Didier, I looked at this package, and see that it contains a dll and "WIN32API.so". I tried to look up the function of "WIN32API.so", found numerous comments about it including the warning about having various ones. I think that one of the comment I read mentioned a version that comes with SketchUp v8. Since you asked for feedback regarding compatibility with V8, I wondered if it was OK to install your "WIN32API.so". I couldn't find one in the main SketchUp folder so am not sure about what I think I read.
                    Btw, do you use SketchUp's built-in exporter to export pages to dxf, or did you write your own?
                    • KrisidiousK
                      Krisidious
                      I'm wondering why I've paid SketchUp $800 when all I wanted was DWG export... Doh!
                      By: Kristoff Rand
                      • ladcweiL
                        ladcwei
                        @didier bur said:
                        Regards,
                        Thanks for your suggestion,that's really I want.I download the ADO plugin,and I can see the "Automated 2D output"menu under the plugin menu,however,it has lost its function(su7) πŸŽ‰
                        I think it needs an update...... πŸ‘
                        • GaieusG
                          AFAIK it only exports dwg from the Pro version (i.e. the exporter itself is not included) at least that's what I found when tried with my SU 5 free back in 2006 or so - but I may be wrong of course.
                          • honoluludesktopH
                            honoluludesktop
                            @krisidious said:
                            ...........my work flow is
                            sketch on paper,
                            export to layout,
                            export to autocad,
                            export to pdf.
                            I have a different take on work flow that doesn't utilize LO:
                            Pencil sketches
                            Schematic design plans in Cad.
                            Build basic model in Cad by blocks, and link the blocks to production drawings,
                            Export basic model to SU,
                            Visualize in SU,
                            Export revisions to Cad as blocks, or revise in Cad and export by block to SU,
                            Export to render from SU,
                            Complete production drawings in Cad,
                            Print to plotter, or export to pdf.
                            I have had to write a lot of tools in Cad, and SU to support my work flow. I guess the "holy grail" is for LO to become a full functioning 2d Cad production drawing tool. If Google added interaction with LO via the ruby api, I bet that could be accomplished in a reasonable time.
                            • Didier BurD
                              Didier Bur
                              No, I didn't wrote an exporter myself, I used the built-in one (so you need Pro version for DWG export).
                              I'll check this on SU8, regarding the win32api.so problem, and will do a new release if needed.
                              Regards,
                              DB
                              • KrisidiousK
                                Krisidious
                                ahh I feel better now...
                                By: Kristoff Rand
                                • Didier BurD
                                  Didier Bur
                                  Hmmm, does'nt work on SU8 here. It seems it needs a serious cleanup and rework πŸ˜•
                                  DB
                                  • J
                                    jaxcoffee
                                    Holding breath, waiting for update. Let us know when you have something Dider. I know I could use something like what your developing.
                                    Thanks for your work.
                                    • J
                                      jaxcoffee
                                      Just wanted to bump this post to see if any update has been done on the mentioned plugin.
                                      • J
                                        jaxcoffee
                                        Would like to know if there is any update to this plugin yet.
                                        PS. Is there a mailing list or reader feed for the Ruby Library Depot, so I don't have to keep bumping this thread?
                                        • KrisidiousK
                                          Krisidious
                                          as long as you're subscribed to this thread you will get an e-mail any time someone replies...
                                          By: Kristoff Rand
                                          • J
                                            jaxcoffee
                                            Thanks, but that was my concern. Would an update to the plugin be reflected on this thread?
                                            • 1 / 2
