    [Plugin] bim-tools 0.13.4(june 22, 2015)
    206 Posts 37 Posters 238.5k Views 37 Watching
    • brewskyB Offline
      brewsky
      Demo version, still contains bugs
      Updated version:
      • Removed image path from css
      • added webdialogpatch.rb(still contains the temp path)
      • changed html type
      John, I was just uploading this new version when i saw your post, I will compare it with the version you just posted and post another one. Thanks!
      Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
        driven
        I'll give this a spin, I don't see an issue with having concurrent test variations at this stage, for me it's more a test of WD's on mac, different flavors gives me somethings to test against. john
        • brewskyB Offline
          brewsky
          @driven said:
          does the ruby observer rewrite the html on selection changes? I have to re click the house to get the next elements info?
          (here on PC) every time a new set_html, for:
          • if no building element selected: show message and further empty window
          • if you select a (different) building element the dialog updates to show the selected elements info
          • if multiple building elements are selected it shows the values that are the same for all selected elements
            There is no dynamic javascript/AJAX content.
            driven
            So, it's basiclly working, churning out .htmls into --TMP-- folder.
            just read your cross post, because it disappears behind the window I need to re-click the house to see the dialog, and this updates the selection,
            It is also updating when I change selection in view, I just couldn't see it... so I moved the drawing and I can...
            it does need .show_modal to make any sense... john
            • brewskyB Offline
              brewsky
              Cool!
              Ooops, didn't think of this temp folder spamming. Maybe best to just delete the old tmp-html when a new one is loaded? I don't think the timer will work for my dialog because of the many content changes.
              Yes, I forgot to add the show for pc, and show_modal for Mac, I'm currently fixing that...
                driven
                Can the 'old' tmp file can be deleted immediately after it's loaded?
                I'm going to do more test with the timer as it may be useful for other stuff, if not this...
                • PixeroP Offline
                  Pixero
                  Just found that line 19 in clsBimTools.rb shows the console everytime I start SU. Had to edit it away.
                  • brewskyB Offline
                    brewsky
                    Ah thanks for mentioning! That's an old line I have used for easy debugging. I stripped it out...
                    • brewskyB Offline
                      brewsky
                      Today "officially" posted the new version I have been working on.
                      See the first post...
                      Still need to fix bugs(infinite loops/too much overhead etc.)
                      Also have to improve on the webdialog temp files.
                      And IFC support...
                      But I'm getting there!
                      Cheers,
                      Jan
                      • Z Offline
                        ZFRPS
                        Good job!refuel!
                        sketchup is bim
                        • guanjinG Offline
                          guanjin
                          And IFC support...
                          Cheers,
                          Jan
                          Open the tool always show this, do not know how to use
                          No BIM-Tools entities selected
                          I come from China, is to learn
                          • brewskyB Offline
                            brewsky
                            I need to make a little tutorial to explain how it works, I will try to that after the weekend.
                            You first need to select some faces and press the second button in the toolbar, the faces will be "converted" to BIM-objects.
                            The message "No BIM-Tools entities selected" will be replaced by object-properties when you select a BIM-object.
                            I hope this gets you started 😄
                            Thanks for trying anyway!
                            • guanjinG Offline
                              guanjin
                              Thank you, I do not see video
                              • guanjinG Offline
                                guanjin
                                @guanjin said:
                                Thank you,China
                                ,I do not see video
                                • Z Offline
                                  zensor
                                  Thanks you very much
                                  • brewskyB Offline
                                    brewsky
                                    Hi Guanjin,
                                    Check the first post, I have added a little tutorial with images.
                                    I hope this helps you out because I don't exactly understand what you mean by "video".
                                    Cheers,
                                    Jan
                                    • brewskyB Offline
                                      brewsky
                                      New version 0.10.3 uploaded!
                                      I wonder what you think, especially about the workflow!
                                      Is it intuitive, sketchup-like? What must be improved?
                                      I made the interface as lean as possible, not a separate button for walls/roofs/floors, just thick faces with properties.
                                      Is this the way to go?
                                      I know it still has bugs(losing relations, sometimes crashing), "bugreports" are also welcome!
                                      Cheers!
                                      Jan
                                      • JQLJ Offline
                                        JQL
                                        I just downloaded it and it's impressive. I couldn't believe my eyes when I saw almost the same workflow I use in SU, reproduced with 3 buttons. The main difference is I create a group for all exterior walls/roofs and if I need to edit one or more specific walls/roof slabs, I then divide those groups. In this way it is simpler for me to edit everything... This plugin might change that though.
                                        I also like the way face offset works. Setting it to zero makes it very simple to work volumes, extruding them in. However, when you toggle to element view, I think it should hide the source faces. Of course this is only visible when offset has a given value, and for me this would happen only when working on interior walls. Nevertheless it would be a very nice feature to implement if it is possible.
                                        This is also true for corners. The plugin also creates border faces for each wall/slab corner wich should not appear when you create a section. It would be nice if these border faces could also be hidden. If the plugin could do this, then we could create a section only with the finishing lines active and no diagonals in the corners.
                                        Definetely the way to go. Simple, effective, clean. The way it should be in Sketchup. I would have a request for one more button though. It would be wonderful if there would be also a button to disconnect/reconnect the faces created. You could then disconnect the faces of a wall for instance, edit that wall, and then reconnect all the faces. This would be most welcome when you want to create special non-uniform walls, walls with unparalell faces or any kind of correction to geometry in dificult corners where some gaps and misajustments happen. It could also be used to correct the bugs you mention below like losing relations between source faces and elements. If one can disconect a face that is not working and erase all associated geometry (but not window components), one would also be able to rebuild it from scratch "debugging" the model. Of course some of the features of windows and dynamic thickness would be lost, but project freedom and overall organization would be kept.
                                        The main inconvenience I found is that if the user doesn't follow the specific steps to make it work right, faces and elements start to fail and some of them disappear. In a creative and interactive process, specially on early stages of a project, this might mean that sometimes you will have to discard the whole model and start over for it to work.
                                        In the present state it is definetely a very useful plugin for simple geometry projects. However for more complex ones I think users would benefit if they had more flexibility with the disconnect/reconnect faces button.
                                        Having said everthing I felt, I think this will be an extremely useful plugin if it gets a little more solid. It could very well be, one of those that really enhances SU. Congratulations!
                                        www.casca.pt
                                        Visit us on facebook!
                                        • brewskyB Offline
                                          brewsky
                                          Thanks! And thanks for your input! I have already added a few of your ideas!
                                          I think I normally work in a similar way, but that's one of the things in my workflow I would like to change with this plugin, if it works right the plugin could reduce the number of groups/components that you have to edit/keep up-to-date.
                                          Great idea! didn't think of using it like that but it gives more direct control over the walls.
                                          It should hide the source faces, only edges should be visible. I think I can easily hide them but didn't work on that yet because i have some ideas for the edges I didn't get to yet. But maybe it's a good idea to temporarily fix this!
                                          Great idea! fixed in the new 0.10.4 version!
                                          I have to think a bit about the disconnect button, wouldn't it be better to just disconnect a single edge? For example when a wall must connect to another wall, but not to the roof?
                                          Meanwhile I have created a button for "deleting BIM properties", works great for fixing bugs!
                                          Yes, that's the biggest reason why it's not "production-ready", but this new button helps a bit in the "fixing".
                                          One thing that fixes some problems is just save your work and re-start SketchUp, the plugin will then re-load the "BIM-properties".
                                          A big problem is still that you have to close SketchUp between switching models, otherwise relations are lost.
                                          Let me know what you think of this new button 😄
                                          • guanjinG Offline
                                            guanjin
                                            The earliest of these features are not, or this is more practical, the new version, we must have a surface in order to add a thickness.
                                            I like the earlier versions, if they can deepen the better, Thank for your hard work
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 6 / 11
