    [Plugin] bim-tools 0.13.4(june 22, 2015)
    206 Posts 37 Posters 243.0k Views 37 Watching
      driven
      @thomthom said:
      I find it very odd if WebKit render documents sans any doctype as HTML5. It would break old sites.
      what I'm say is the opposite WebKit render documents as HTML5sans any doctype. if it has no html 5 content it won't add it...
      • brewskyB Offline
        brewsky
        @driven said:
        I've got this working to the extent of mimicking your 'youTube' clip,
        Great!
        @driven said:
        plus the minimise button which took forever to get hold of.... It was only after I noticed it's missing from your demo....
        O how stupid of me, i didn't even notice... I made the video on linux(wine). The button is not working in the current version, i stripped out all the javascript. I was planning to recreate the full html on each action using set_html, to keep the webdialog simple. Maybe it's automatically fixed when it works on safari(I don't know if wine uses a version of IE, or the default linux browser).
        @driven said:
        why are you using 1999 XHTML? it's 2012...
        Didn't give that much thought(didn't even realize there would be differences between MAC and PC, when I started out).
        I tried to keep it as common as possible. Having a DTD seemed very important, how else could a browser pick the correct way of rendering? But when i read a bit more about HTML5 it seems they left the DTD out ?! And xml-style(like <br />) is valid if you want to, but does not seem to be the preferred way...
        When I read a bit more about HTML5, this seems the cleanest:
        <!DOCTYPE html>
        <html>
        </html>
        I changed this in my code, no problems on IE9, I will also give it a try on IE8...
        But declaring the additional
        <meta charset=utf-8'>
        seems a good idea. And maybe a language identifier???
        Would be great if google used a built-in chrome for SketchUp for PC, it beeing webkit-based would simplify things.
        And then I could use the http://bimsurfer.org/ webGL IFC viewer from inside SketchUp to check the model in IFC format! ๐Ÿ˜„
        @driven said:
        the other was you have two different image paths
        I will try your other trick for the temp files...
        Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
        • brewskyB Offline
          brewsky
          @driven said:
          seemingly valid on mac
          <meta http-equiv='refresh' content='30' />
          Would this not mean that the webdialog is only refreshed every 30 seconds?
          I'm planning to refresh the webdialog on every selection change in sketchup, I guess it will not work in that case, right?
          @driven said:
          with this you only need the one temp file
          		@tmpPath=(@pathname + '/btDialog.html')
          > 		@tmpFile=(File.open(@tmpPath, 'w+'))
          with relative links for js, images and css, much cleaner.
          Is the @pathname in this case "/tmp" or the normal path to the SketchUp plugins folder?
          Otherwise I don't really understand the "relative links".
            driven
            These is all the changes except a copy of the image file is also added to ui folder, there's a couple of puts that aren't needed...
            I tried a 1second refresh, but you can't change anything that quick... also tried 3 + 3000
            The 30 second refresh, allows enough time to make changes and submit, but time may be irrelevant (as long as it's enough), having this appears to allow resetting in general, which doesn't happen by default in WD's, does the ruby observer rewrite the html on selection changes? I have to re click the house to get the next elements info? The webdialog doesn't auto update that...
            #       bt_dialog.rb
            #       Copyright (C) 2011 Jan Brouwer <jan@brewsky.nl>
            #       This program is free software; you can redistribute it and/or modify
            #       it under the terms of the GNU General Public License as published by
            #       the Free Software Foundation, either version 3 of the License, or
            #       (at your option) any later version.
            #       This program is distributed in the hope that it will be useful,
            #       but WITHOUT ANY WARRANTY; without even the implied warranty of
            #       MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
            #       GNU General Public License for more details.
            #       You should have received a copy of the GNU General Public License
            #       along with this program.  If not, see <http://www.gnu.org/licenses/>.
            class Bt_dialog
              def initialize(project)
                @project = project
                bt_lib = @project.library
                # Create WebDialog instance
                @dialog = UI;;WebDialog.new("BIM-Tools menu", false, "bim", 243, 150, 150, 150, true)
               		 @dialog.min_width = 243
            		 @dialog.min_height = 25
            		 @dialog.max_width = 243
            		 @dialog.max_height = 1200
            		 @dialog.set_position(150,150)
                @pathname = File.expand_path( File.dirname(__FILE__) )
                mainpath = @pathname.split('ui')[0]
                @imagepath = mainpath + "images" + File;;SEPARATOR
                @bt_lib = bt_lib
                @javascript = ""
                # create BIM-Tools selection object
                require 'bim-tools/lib/clsBtSelection.rb'
                @selection = ClsBtSelection.new(@project, self)
                @h_sections = Hash.new
                # define sections
                require 'bim-tools/ui/clsEntityInfo.rb'
                entityInfo = ClsEntityInfo.new(self)
                @h_sections["EntityInfo"] = entityInfo
                #@h_sections["ProjectData"] = ClsProjectData.new
                 		# PC Load paths will have a ';' after the drive letter.
            		@is_mac = ($LOAD_PATH[0][1..1] != ";")
            		puts 'mac'
            		#@tm=(rand(9999).to_s.strip)
            		@tmpFile.rewind
            		@tmpFile.puts html
            		@tmpFile.rewind
            		@dialog.show_modal
            		@dialog.set_file(@tmpPath)
              if File.exists?(@tmpFile)
            	@tmpFile.close
            	puts 'closed'
                # Attach the observer.
                Sketchup.active_model.selection.add_observer(MySelectionObserver.new(@project, self, entityInfo))
              def refresh
                @dialog.set_file( html )
              def html
                content = ""
                @h_sections.each_value do |section|
                  content = content + section.html
                return html_top + content + html_bottom
              def html_top   #Note that XHTML 1.0 previously defined that documents adhering to the compatibility guidelines were allowed to be served as text/html, but HTML 5 now defines that such documents are HTML, not XHTML.
                return "
                <!DOCTYPE html>
                <html>
                <head>
                <meta charset='UTF-8' />
                <title>BIM-Tools - webdialog</title>
                <link href='" + @pathname + "/bt_dialog.css' rel='stylesheet' type='text/css' />
                </head>
                <body>
              def html_bottom
                return "
                </body>
                </html>
              def webdialog
                return @dialog
              def close
                if @dialog.visible?
                  @dialog.close
              def selection
                return @selection
              def imagepath
                return @imagepath
              def project
                return @project
              end  # This is an example of an observer that watches the selection for changes.
              class MySelectionObserver < Sketchup;;SelectionObserver
                def initialize(project, bt_dialog, entityInfo)
            			@project = project
            			@bt_dialog = bt_dialog
            			@entityInfo = entityInfo
            		def onSelectionBulkChange(selection)
            			# open menu entity_info als de selectie wijzigt
            			#js_command = "entity_info(1)"
            			#@dialog.execute_script(js_command)
            			#js_command = 'entity_info_width("' + width.to_s + '")'
            			@entityInfo.update(selection)
            			#@bt_dialog.webdialog.set_html( @bt_dialog.html )
            		def onSelectionCleared(selection)
            • brewskyB Offline
              brewsky
              Demo version, still contains bugs
              Updated version:
              • Removed image path from css
              • added webdialogpatch.rb(still contains the temp path)
              • changed html type
              John, I was just uploading this new version when i saw your post, I will compare it with the version you just posted and post another one. Thanks!
                driven
                I'll give this a spin, I don't see an issue with having concurrent test variations at this stage, for me it's more a test of WD's on mac, different flavors gives me somethings to test against. john
                • brewskyB Offline
                  brewsky
                  (here on PC) every time a new set_html, for:
                  • if no building element selected: show message and further empty window
                  • if you select a (different) building element the dialog updates to show the selected elements info
                  • if multiple building elements are selected it shows the values that are the same for all selected elements
                    There is no dynamic javascript/AJAX content.
                    driven
                    So, it's basiclly working, churning out .htmls into --TMP-- folder.
                    just read your cross post, because it disappears behind the window I need to re-click the house to see the dialog, and this updates the selection,
                    It is also updating when I change selection in view, I just couldn't see it... so I moved the drawing and I can...
                    it does need .show_modal to make any sense... john
                    • brewskyB Offline
                      brewsky
                      Cool!
                      Ooops, didn't think of this temp folder spamming. Maybe best to just delete the old tmp-html when a new one is loaded? I don't think the timer will work for my dialog because of the many content changes.
                      Yes, I forgot to add the show for pc, and show_modal for Mac, I'm currently fixing that...
                        driven
                        Can the 'old' tmp file can be deleted immediately after it's loaded?
                        I'm going to do more test with the timer as it may be useful for other stuff, if not this...
                        • PixeroP Offline
                          Pixero
                          Just found that line 19 in clsBimTools.rb shows the console everytime I start SU. Had to edit it away.
                          • brewskyB Offline
                            brewsky
                            Ah thanks for mentioning! That's an old line I have used for easy debugging. I stripped it out...
                            • brewskyB Offline
                              brewsky
                              Today "officially" posted the new version I have been working on.
                              See the first post...
                              Still need to fix bugs(infinite loops/too much overhead etc.)
                              Also have to improve on the webdialog temp files.
                              And IFC support...
                              But I'm getting there!
                              Cheers,
                              Jan
                              • Z Offline
                                ZFRPS
                                Good job!refuel!
                                sketchup is bim
                                • guanjinG Offline
                                  guanjin
                                  And IFC support...
                                  Cheers,
                                  Jan
                                  Open the tool always show this, do not know how to use
                                  No BIM-Tools entities selected
                                  • brewskyB Offline
                                    brewsky
                                    I need to make a little tutorial to explain how it works, I will try to that after the weekend.
                                    You first need to select some faces and press the second button in the toolbar, the faces will be "converted" to BIM-objects.
                                    The message "No BIM-Tools entities selected" will be replaced by object-properties when you select a BIM-object.
                                    I hope this gets you started ๐Ÿ˜„
                                    Thanks for trying anyway!
                                    • guanjinG Offline
                                      guanjin
                                      Thank you, I do not see video
                                      • guanjinG Offline
                                        guanjin
                                        @guanjin said:
                                        Thank you,China
                                        ๏ผŒI do not see video
                                        • Z Offline
                                          zensor
                                          Thanks you very much
                                          • brewskyB Offline
                                            brewsky
                                            Hi Guanjin,
                                            Check the first post, I have added a little tutorial with images.
                                            I hope this helps you out because I don't exactly understand what you mean by "video".
                                            Cheers,
                                            Jan
                                            • 11
                                            • 6 / 11
