    INTERIOR
    23 Posts 12 Posters 3.3k Views 12 Watching
    • N Offline
      nomeradona
      I was writing a new tutorial on interior with different lighting sources (ies, daylight, double sided materials, spotlight, omni, etc). I edited the same model that i used with my first interior with the old vray, added some new decors, furnitures mainly from trangan, then ended up having this render.
      sketchup 7 and vray sketchup
      too big to put here directly whilst i did a thumbnail to photobucket to view a bigger size.
      http://i334.photobucket.com/albums/m421/nomeradona_1234/Rendering and visualization/th_final_nomeradona.jpg
      http://nomeradona.files.wordpress.com/2011/03/render-interior-done.jpg
      visit my blog: http://www.nomeradona.blogspot.com
      • simon le bonS Offline
        simon le bon
        Hi Nomeradona,
        I would like to be able one day to achieve such render. ๐Ÿ‘
        I must also say that your blog is impressive ๐Ÿ˜ฎ
        And also thank you for the nice textures you are sharing in ๐Ÿ˜‰
        ++simon
        • urgenU Offline
          urgen
          ... great! ๐Ÿ‘ โ˜€
          --pupil forever...------
          • soloS Offline
            solo
            Hey Nomer, long time no see.
            Welcome back to SCF and Vietnam (noticed on Facebook you returned)
            Awesome as always mate.
            http://www.solos-art.com
            • FrederikF Offline
              Frederik
              Really nice model and render...!! ๐Ÿ‘
              Cheers
              Kim Frederik
              • Bryan KB Offline
                Great model and great render. It looks very inviting.
                • soloS Offline
                  solo
                  Really? well your skills are still strong.
                  I did 247 paid renders (big and small, one client commissioned 137) and about 300 playtime/test renders last year.
                  • N Offline
                    nomeradona
                    thanks to all of your comments. i appreciate them all.
                    @ pete.. i always wanted to honed my modeling and rendering, but my work keeps pulling me away from that. that is why whenever i found some breaks i come back. I can't believe that for a year i only managed to do less than 15 renders. ๐Ÿ‘Ž
                      jsteacy
                      Great image, I really like the lamp shade material. Did you model the pillows in sketchup? I've only attempted pillows a couple of times in sketchup and have gotten ok results.
                      • N Offline
                        nomeradona
                        that is indeed a good hobby. you play.. you enjoy and make money.
                        • N Offline
                          nomeradona
                          pillows were imported 3ds.
                          • I Offline
                            ivanscotti
                            Very nice render, itโ€™s clear that you are completely master of this great engine (V-Ray).
                            But, since we're talking about an image that is close to perfection, i would like to expose some constructive criticism:
                            The window on the left, in my opinion should be brighter, like the one that sees in the mirror.
                            So even the black shiny sphere on the window sill, should have a much light and brighter reflection (being in front of the window).
                            Finally (and this is perhaps the most important point), in my opinion there is something that does not return correctly with the lighting:
                            It seems that the main light source comes from above instead of directly from the windows and lamps.
                            Just look at the shadows under the cushions, under the picture frames and under the window sill.
                            They are all shades of light coming directly from above, as if the ceiling had a light source stronger than those visible in the scene (this becomes very obvious lightening the image with photoshop).
                            But if so, the higher parts of the walls should be brighter than that.
                            In addition, the table (taking the light from the window), should throw its shadow on the pillow to the right of the image. but this does not happen!
                            Perhaps this depends on your own research in this picture to illuminate the scene with different light sources.
                            It may be that you used a fill light, but you forgot to eliminate shadows.
                            Or maybe it's me that i did not understand much. ๐Ÿ˜ณ
                            However this is just my opinion, and all in all i think that the image in question is really very impressive, although there are some points that i believe must be resolved, to obtain a realistic and proper lighting of the scene.
                            ivan
                            "With great power comes great responsibility".
                            Spiderman
                            my website: http://www.area63.it
                            • N Offline
                              nomeradona
                              thanks ivan for you crits. much appreciated.
                              • N Offline
                                nomeradona
                                Here is another one, no BG and GI color.
                                [size=200:2m9epv1f]
                                http://i334.photobucket.com/albums/m421/nomeradona_1234/nightrendering2.jpg
                                • I Offline
                                  ivanscotti
                                  Thank you Nomer, i saw all your work on your blog and on deviantArt, and i have to congratulate with you again for your professionalism and your art.
                                  This last image you posted, that night, i feel so much better. I would say perfect! ๐Ÿ‘
                                  See you
                                  Ivan
                                  Spiderman
                                    steelers05
                                    nice to see your work again bud, good job.
                                    • N Offline
                                      nomeradona
                                      thank you steeler. appreciate.
                                      • RichardR Offline
                                        Richard
                                        STUNNING WORK! Mate!
                                        Wow everything is balanced well, I'd probably like to see the downlight in the recess throwing a bit more light just to drag the eye to the interest there.
                                        BTW mate is the finish to the window shelf right? It looks to be the same as what I would imagine as paper on the walls!
                                        Well done mate, makes me want to be in the room and soak it up! Exactly what you were trying to project I'm sure!
                                        [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                        • N Offline
                                          nomeradona
                                          hi richard,
                                          coming from a great maxwell rendere like is humbling. but im happy with your comment. ๐Ÿ˜„
                                          you are absolutley right in increasing that light. i actually gave that IES a bit more of multiplier to get the effect lighting on that niche to be highlighted but i end up overburned on the floor. im actually having a dilemna if it s the wall color or if it is the IES data. but my suspect would be the green color.
                                          I wanted to achieved a wall paper effect on the wall. Matte finish.
                                          • michaliszissiouM Offline
                                            michaliszissiou
                                            Amazing work nomer. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                            So glad to see you posting, best wishes for a creative new year.
                                            • 1 / 2
