Building Walls
 Of course
 how about Double Line? you can set the width and height and trace it along the lines. testing on the detailed SU file took about 2 minutes for about 30% and the walls are all straight and even. downside - no grouping but easy enough to then punch holes etc.
 Double Line cannot handle T junctions, only a simple path. As I pointed out that detailed plan is less than 1% of the total area to be modelled so I am not wanting anything that requires "cleanup". I was looking for a single-step solution. Streetgen gives that with virtually no cleanup required.
 @unknownuser said: Double Line cannot handle T junctions, only a simple path. Right.
 Since your walls are groups they also are 'solids', then performing 'union' gives good results.
 But more parameters in the dialog box would be handy and useful.
 Keep on the good work.
