    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 326.0k Views 89 Watching
    • U Offline
      unclex
      if { mx_hidemanager.rb (C) 2010 by Henry Schorradt } this plugin was loaded,
      when set [Allow Collision] no, run CompoSpray
      SU8Pro crashed.....
        dcrites
        Does anyone have a solution for the problem which Pilou posted earlier? I have a 15" HP Laptop running windows 7, with Google Sketchup 8 -
        I'm a Landscape Architecture student, so spraying trees rather than placing them individually would be an absolute godsend. But if I can't get to the bottom of the screen, I can't do much. I've tried using the 'tab' key to get to the 'spray' icon, but it doesn't seem to work (though tabbing over to the 'close' icon does. Arg.
        768 pixels is the maximum height on my monitor.
        • Didier BurD Offline
          Didier Bur
          I'll release an update soon with settings for low res screen that will set up scrollbars and modal/non modal dialogs. Easy and quick translation files will be supported as well.
          Regards
          DB
          • charly2008C Offline
            charly2008
            Hi Didier,
            Thank you for this plugin.
            I have a question. I have two entries in the Draw menu, Components and Component Spray. But I do not know what I can delete in the plugins folder. Can you help me please.
            Charly
            Draw Menue
            Plugins Folder
              charly2008
              Problem solved!
              I have found it. It is the compo_spray.rb.
              Charly
                Didier Bur
                Yes compo_spray.rb was an older version. Never have more than one install at a time 😆
                DB
                  arjunmax09
                  component spray doesn't allow spraying while editing inside a group..how can i do that...??...i have to copy paste the sprayed components inside the group separately...
                  when you fail at something....you haven't really failed...you've found one way the thing will not work out
                    Didier Bur
                    @arjunmax09: of course you can spray while editing a group or component: double-click on the group/component, click the compoSpray icon and here you go.
                    DB
                      arjunmax09
                      yes....i also tried at my home pc..it worked fine...i was working at my groupmate's place on his pc when i posted this question..there i wasn't able to do so 😒 I haven't downloaded this version yet...i.e. the 8th jan 2011 version...
                        charly2008
                        I installed this update and all is working fine. But i miss the drop down menue i couldn't find (See Image below).
                        Charly
                          tulacong
                          Great start for 201x
                            Didier Bur
                            Hi Charly,
                            To get this menu, you must select faces PRIOR to click on the icon.
                            Do you still miss this menu when doing that ? 😲
                            DB
                              charly2008
                              Hi Didier,
                              the problem still exists.
                              Charly
                                Didier Bur
                                Charly,
                                I don't see any problem here: the face is selected, so the dropdown list contains "selected faces" and "vertices of faces".
                                Close the dialog box, unselect all, re-launch compoSpray, it should now display the usual dropdown list , right ?
                                charly.swf
                                DB
                                  charly2008
                                  Hi Didier thanks,
                                  I tried it again, now I have understood it.
                                  If in the dialog box the component is selected, but no face is selected, than the pull down menu with the shapes is shown.
                                  If in the dialog box the component is selected and the face is selected than the spray type menu is shown.
                                  Charly
                                    charly2008
                                    Now that I have understood correctly, it excites me to return to the experiment.
                                    Charly
                                    Untitled.skp
                                    • simon le bonS Offline
                                      simon le bon
                                      Now I see what it is possible to achieve with Charly, I'm one step more contrite that Compo Spray doesn't work for me 😞
                                      -s
                                        Didier Bur
                                        Patience Simon... je vais publier la v 1.4.2 bientôt.
                                        With an experimental directional spray:
                                        DB
                                          simon le bon
                                          Ah c'est chouette!!
                                          et le directional spray va décupler les possibilités. 😄
                                          (ça mérite la patience 😉 )
                                          😎 simon
                                          • pep75P Offline
                                            pep75
                                            Hey Didier!
                                            I really can't get it working...I see the dialog still, I read your manual, pressed Spray but It doensn't do anything....What is wrong?!
                                            Thanks!!
                                            Grtz
                                            Pep
                                            • 6
                                            • 13
                                            • 14
                                            • 4 / 14
