    How to close Sketchup
    13 Posts 4 Posters 1.6k Views 4 Watching
    • honoluludesktopH
      honoluludesktop
      Is there a way to shut down the current instance of Sketchup from a plugin?
      • honoluludesktopH
        honoluludesktop
        Found this. However, not elegant or documented.
        • J
          Jim
          Here's Dan's code:
          http://forums.sketchucation.com/viewtopic.php?f=180&t=29162&hilit=safe+shut+down
          • honoluludesktopH
            honoluludesktop
            Jim, thanks, I missed that post.
            • honoluludesktopH
              honoluludesktop
              Thanks to everyone, Taking a bit from both, however yet untested on a Mac:
              begin
                #or 57602 pc only
                Sketchup.send_action 57665
              rescue
                 #mac only
                Sketchup.send_action('terminate;')
              If the pc version fails, must be Mac. Hope the command is OK.
              • thomthomT
                Instead of try and rescue you can detect the OS:
                <span class="syntaxdefault"><br />  </span><span class="syntaxcomment"># @return [Boolean]<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @since 2.4.0<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_osx</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Object</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">RUBY_PLATFORM </span><span class="syntaxkeyword">=~</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">/</span><span class="syntaxdefault">darwin</span><span class="syntaxkeyword">/</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> true </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> false<br />  end<br />  <br />  </span><span class="syntaxcomment"># @return [Boolean]<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># @since 2.5.0<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_windows</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">!</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_osx</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  end<br /><br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close_sketchup<br />    if self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_osx</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">      Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'terminate;'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    else<br />      Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">57665</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    end<br />  end<br /></span>
                • Dan RathbunD
                  Dan Rathbun
                  sending action 57602 does a "dirty" terminate of Sketchup (similar to using the Task Manager to shut down an app. You really should NOT use it, unless of last resort.)
                  I'll modify my [code] post title and remove the "(beta)" as it's proven now.
                  I'm not here much anymore.
                  • Dan RathbunD
                    Dan Rathbun
                    Actually a general way of defining platform variant methods that execute faster.
                    (This method may not be the best example as it would only run once per session.)
                    <span class="syntaxdefault"><br />  if self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_osx</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close_sketchup<br />      Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'terminate;'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    end<br />  else<br />    def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close_sketchup<br />      Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">57665</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    end<br />  end<br /></span>
                    • honoluludesktopH
                      honoluludesktop
                      Thanks, guys. Now I have to go look up, and learn what self.stuff means :-)
                      • honoluludesktopH
                        honoluludesktop
                        Is it possible to close one instance of sketchup from another?
                        • Dan RathbunD
                          Dan Rathbun
                          self refers to the module namespace that you are defining the method within.
                          You could also def the module method like so:
                          module Hawaii
                            def Hawaii.gizmo(arg)
                              puts( arg.to_s )
                          end # module
                          but if you have many module methods in the module, and you later decide to change the module name, you would have to either manually edit each method definition name, or do a search and replace (if your editor has that feature.)
                          Instead, def your module methods like so:
                          module Hawaii
                            def self.gizmo(arg)
                              puts( arg.to_s )
                          end # module
                          and that way, if you change the module name, you only need edit 1 line of code.
                          However, if you instead use my extension method to the Sketchup module, you won't need, to define one within your own module. The drawback is that any user of your plugin must also go and download my extension.
                          • I did log a API Feature Request that my method be added to the Sketchup module on the C side of the Google code, which is why I included a unless method_defined?(:app_safe_shutdown) block around the declaration. If it gets added in a future release, my script will do nothing.
                          You may also wish to go readup on my [info] post on using Ruby modules.
                          [info] Using Ruby Modules
                          to discuss:
                          [talk] Using Ruby Modules
                          • Dan RathbunD
                            Dan Rathbun
                            Probably via a named pipe, but you (and your users,) must either use a standard Ruby pipe library, or a specific platform library like Daniel Berger's win32 utility libraries.
                            • honoluludesktopH
                              honoluludesktop
                              @dan rathbun said:
                              ...........refers to the module namespace that you are defining the method within.........
                              OK, I get that. Thanks.
