    Help inserting a skp into a model.
    6 Posts 3 Posters 423 Views 3 Watching
    • honoluludesktopH Offline
      honoluludesktop
      The only method I have found to import a skp into my model is model.import "my_file_name.skp". However, this method places the import on the tip of my pointer, not in the model. How do I import a skp, to a specific point in the model independently of a pointing device?
      If I can import the skp as a definition, or instance to the model, then I could do something like definition.insertion_point=Geom::Point3d.new(x,y,z). But I have not figured out how to do that. Any ideas?
      • Dan RathbunD Offline
        Dan Rathbun
        try Entities.add_instance
        I'm not here much anymore.
          Entites.add_instance requires the instance to exist.
          What you want to use is model.definitions.load
          http://code.google.com/intl/no/apis/sketchup/docs/ourdoc/definitionlist.html#load
          Then you can use model.active_entities.add_instance
            Dan Rathbun
            Yes and the code example under Entities.add_instancehas all that.
              Gotcha - didn't notice that.
                honoluludesktop
                Thanks guys.
