    Display Section Cuts
    6 Posts 3 Posters 513 Views 3 Watching
    • G Offline
      GWD
      Is there a way to control the 'Display Section Cuts' with ruby?
      • Dan RathbunD Offline
        Dan Rathbun
        I looked thru the SU Registry settings and it is not there.
        We would expect these settings to be kept in the model's and page's RenderingOptions hash, but I dont see it there either.
        PC ONLY:
        Toggle "Display Section Planes"
        Sketchup.send_action(21347)
        Toggle "Display Section Cuts"
        Sketchup.send_action(21348)
        These are equivalent to telling the Windows API to perform the default action on the control (toolbar button in this case,) with the given Automation ID.
        For a query.. it might be possible to use a call thru Win32API class, to get the checked state of the button. (The toolbar window name is "Sections" for US-en, and it's Automation ID is 477.)
        Or, you might get the View menu object and check the checked states of the menu items, again via a Win32API call.
        I'm not here much anymore.
        • G Offline
          GWD
          PC ONLY:
          Thanks Dan the toggle is good enough for me. But i read something that the send_action with a code doesn't work on the mac version. Do you know if this is correct?
            Dan Rathbun
            I believe that is correct because the platforms are built with different Automation IDs. (I'm not a Mac guy, but I think the Mac IDs are strings, rather than integers, as on Windows.)
            What we need is a cross-platform Sketchup.send_action() string, or these keys added to the RenderingOptions hash.
            • G Offline
              GWD
              I agree. What we need is that everything what you can do with SU is also supported in the API. I don't know why there are some parts that aren't supported (sectionplanes, Export 2D graphic (dxf), ...)
                Dimensions, several Material & Layer methods ... the list goes on... 😞
