    Unlimited Zoom
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    15 Posts 5 Posters 11.1k Views 5 Watching
      Jim57
      I often model items (sculpture, furniture) in SU and print from LO, full size if possible. I print on 3' x 4' sheets, as that is the largest digital copy I can make at the local copy shop.
      When I work with 36" w x 48" h paper I cannot shrink the image of the sheet small enough to see the whole thing at once. This makes it very difficult to lay out a page nicely, and quite inconvenient to adjust the different images on the sheet.
      Could you change the limits on LayOut to allow more zooming?
      Thanks,
      Jim
      • fouronethirtyF Offline
        fouronethirty
        ANOTHER PROBLEM IS the limitation on zooming in, its hard to edit line when not zoomed in for a wide view ,
          fouronethirty
          i wish l.o hav more zoom:)
          and scheduling of line weights, like ,clicking on all the lines first that you want to change heirarchy and then with the right click mouse function to choose the line weights which is scheduled in a layer, just right clicking to choose lineweights, i just think it would be a faster move than draging mouse to the shape style tab and choosing line weights there, thank you.
            samyell77
            Yes yes - unlimited zoom PLEASE and better snapping in non vector'd views.
            SU Pro 2016
            Dell Precision M4800
            PC Windows 10
            Intel Core i7-4900MQ @ 2.80ghz
            Nvidia Quadro K2100M
            16gb RAM
            • mitcorbM Offline
              mitcorb
              This may be a dumb question, and I do not use Layout, but is the zoom in Layout any different than in Sketchup?
                samyell77
                Yup - the amount of zoom is restricted in Layout. Try it out!
                SU Pro 2016
                PC Windows 10
                16gb RAM
                • mitcorbM Offline
                  mitcorb
                  Then I would ask the developers: What is it in C++, OpenGL, and whatever else is going on behind the curtains that makes this application any different than the other? I just thought Layout was a special case of Sketchup.
                    samyell77
                    Its the drafting application for producing drawings of sketchup models.
                    SU Pro 2016
                    PC Windows 10
                    16gb RAM
                    • mitcorbM Offline
                      mitcorb
                      Yes, I understand that. But you all asked for unlimited zoom, and I am asking what makes that impossible, or difficult to implement in Layout.
                        samyell77
                        Its a restriction in the program its self - bit hard to explain if you haven't used layout. On SU you can zoom to infinity (an beyond I guess) but in layout the zoom stops so you cant get any closer to what you are looking at. The amount of zooming you can do is restricted so its impossible because the application wont allow you to zoom any futher. Easier if you actually have a look at Layout and will see what people are talking about.
                        SU Pro 2016
                        PC Windows 10
                        16gb RAM
                          fouronethirty
                          that discussion should be just enough for the sketchup developers, if only they can hear us. more zoom for layout, more power to the sketchup developer
                            fouronethirty
                            line scheduling, color dependency, and so l.o can move faster on handling huge file or project, and the vectorizing of lines, from raster to vector, sometimes l.o find it hard to do it, vectorizing huge amount of lines, thats another problem, layout is very good, but it has some hardtimes when encountering biger files
                              fouronethirty
                              more zoom please,\:) ,
                                fouronethirty
                                it the only thing that L.O needed. more zoom. l.o can only zoom at 1000% . and when you happen to be working on a scale 1:200 in metric . it goes hard to edit vector lines which is very important in architectural drafting line heirarchy. it'll be great once l.o have this kind of improvements,
                                  driven
                                  have you tried this on your mac, takes a little practice
                                  http://www.bbc.co.uk/accessibility/guides/magnify/computer/mac/os_x/index.shtml
                                  john
