    Move a Parallel Camera
    15 Posts 5 Posters 1.0k Views 5 Watching
      Jim
      I have this snippet to zoom out - just moves the camera away from the taget along the line-of-sight. Any idea why it works when the Camera is Perspective, but not Parallel?
      factor = 0.5
      model = Sketchup.active_model
      view = model.active_view
      c = view.camera
      t = c.target
      e = c.eye
      up = c.up
      vec = t - e
      vec.length = vec.length * factor
      c.set(e-vec, t, up)
      • Chris FullmerC Offline
        I changed the factor to 1000 and ran it about 10 times really fast.....that broke my SketchUp 😄
        I have not got the right answer, but in parallel mode, backing the camera out should not widen the view of what is ont he screen. It seems like you would need to widen the FOV or something to make it feel like you are backing up.
        All my Plugins I've written
          Jim
          Thanks Chris, that makes sense.
          When I plot the Camera eye over several "zoom outs", the cpoints do indicate the Camera is moving away.
          So I'm still not sure why the view doesn't appear to move, even if the Camera is. Zoom and Pan still work with a Parallel Camera. Moving the Camera away should still make everything appear smaller.
          • mitcorbM Offline
            mitcorb
            I don't really know what I'm talking about, but from an intuitive view, do you have to transform the OpenGL frustum or camera cone of vision in order for the display to "shrink"? Or is the frustum a fixed thing and ...mumble...mumble??
            • Dan RathbunD Offline
              Dan Rathbun
              Does appending a call to view.refresh (at the end of the code,) have any effect ??
              I'm not here much anymore.
                Jim
                No, no difference.
                I did notice that when I switch back to a Perspective Camera, the camera jumps way back.
                  Dan Rathbun
                  OK.. and what happens when you switch back to Parallel ?
                    Dan Rathbun
                    A few other questions:
                    Do these have any effect?
                    view.invalidate()
                    view.dynamic=true
                      Jim
                      Neither has nay effect.
                        Maybe change to perspective mode, then move, then jump back to parallel? Or do that on a camera that is not active_view and then apply that camera to the active view?
                          Jim
                          Yep, thanks. I can make something work. I guess at this point I am curious to understand what's going on.
                            Dan Rathbun
                            That is what I meant when I asked:
                              Dan Rathbun
                              Solved.
                              This code works no matter what mode the camera is in, AND resets the mode back to the previous mode. (See ### bracketed statements that I added.)
                              zoomtest.rb
                              <span class="syntaxdefault"></span><span class="syntaxcomment">#<br /><br /></span><span class="syntaxdefault">module SU_Test<br /><br />  </span><span class="syntaxcomment">#<br /><br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">zoomtest</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">    factor </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0.5<br />    model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />    view </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view<br />    c </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">camera<br />    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    cp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">perspective</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    t </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">target<br />    e </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">eye<br />    up </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">up<br />    vec </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> t </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> e<br />    vec</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> vec</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> factor<br />    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">perspective</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">true if cp</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">false<br />    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">vec</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> t</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> up</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">perspective</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">false if cp</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">false<br />    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">  end<br /><br />  unless defined</span><span class="syntaxkeyword">?(@</span><span class="syntaxdefault">LoadedOnce</span><span class="syntaxkeyword">)==</span><span class="syntaxstring">'instance-variable'<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">LoadedOnce</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">false<br />  end<br /><br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">loaded_once</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">LoadedOnce<br />  end<br />  <br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">loaded_once</span><span class="syntaxkeyword">=(</span><span class="syntaxdefault">arg</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">LoadedOnce</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">arg<br />  end<br /><br />end </span><span class="syntaxcomment"># module<br /><br /></span><span class="syntaxdefault">  unless SU_Test</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">loaded_once</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">    UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Plugins'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Zoom Out Test'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> SU_Test</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">zoomtest</span><span class="syntaxkeyword">()</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">    SU_Test</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">loaded_once</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">true<br />    </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  end<br /></span>
                                jhauswirth
                                You need to use camera.height in parallel mode.
                                  Jim
                                  Thank you, that works.
