    Move a Parallel Camera
    15 Posts 5 Posters 1.4k Views 5 Watching
    • Dan RathbunD
      Dan Rathbun
      Does appending a call to view.refresh (at the end of the code,) have any effect ??
      I'm not here much anymore.
        Jim
        No, no difference.
        I did notice that when I switch back to a Perspective Camera, the camera jumps way back.
        • Dan RathbunD
          Dan Rathbun
          OK.. and what happens when you switch back to Parallel ?
          • Dan RathbunD
            Dan Rathbun
            A few other questions:
            Do these have any effect?
            view.invalidate()
            view.dynamic=true
              Jim
              Neither has nay effect.
              • Chris FullmerC
                Maybe change to perspective mode, then move, then jump back to parallel? Or do that on a camera that is not active_view and then apply that camera to the active view?
                  Jim
                  Yep, thanks. I can make something work. I guess at this point I am curious to understand what's going on.
                  • Dan RathbunD
                    Dan Rathbun
                    That is what I meant when I asked:
                    • Dan RathbunD
                      Dan Rathbun
                      Solved.
                      This code works no matter what mode the camera is in, AND resets the mode back to the previous mode. (See ### bracketed statements that I added.)
                      zoomtest.rb
                      <span class="syntaxdefault"></span><span class="syntaxcomment">#<br /><br /></span><span class="syntaxdefault">module SU_Test<br /><br />  </span><span class="syntaxcomment">#<br /><br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">zoomtest</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">    factor </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0.5<br />    model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />    view </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view<br />    c </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">camera<br />    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    cp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">perspective</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    t </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">target<br />    e </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">eye<br />    up </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">up<br />    vec </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> t </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> e<br />    vec</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> vec</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> factor<br />    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">perspective</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">true if cp</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">false<br />    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">vec</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> t</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> up</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    c</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">perspective</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">false if cp</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">false<br />    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">  end<br /><br />  unless defined</span><span class="syntaxkeyword">?(@</span><span class="syntaxdefault">LoadedOnce</span><span class="syntaxkeyword">)==</span><span class="syntaxstring">'instance-variable'<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">LoadedOnce</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">false<br />  end<br /><br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">loaded_once</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">LoadedOnce<br />  end<br />  <br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">loaded_once</span><span class="syntaxkeyword">=(</span><span class="syntaxdefault">arg</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">LoadedOnce</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">arg<br />  end<br /><br />end </span><span class="syntaxcomment"># module<br /><br /></span><span class="syntaxdefault">  unless SU_Test</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">loaded_once</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">    UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Plugins'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Zoom Out Test'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> SU_Test</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">zoomtest</span><span class="syntaxkeyword">()</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">    SU_Test</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">loaded_once</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">true<br />    </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">  end<br /></span>
                        jhauswirth
                        You need to use camera.height in parallel mode.
                          Jim
                          Thank you, that works.
