    SketchyPhysics3.2 (Dec 2)
    55 Posts 23 Posters 24.4k Views 23 Watching
      CPhillips
      The 3.2 version of SP is ready. This version should finally work on Mac. Sorry for the delay.
      Try it out and if works (or doesn't) please let me know. As soon as it seems it is stable I will turn on the auto update notice.
      Google Code Archive - Long-term storage for Google Code Project Hosting.
      (code.google.com)
      This is mostly the same as the last 3.2 test. Plus a few bugs fixed.
      Old samples in this thread:
      http://forums.sketchucation.com/viewtopic.php?f=61&t=32200
      I will make some new ones when I get a chance.
      Change log:
      http://code.google.com/p/sketchyphysics/wiki/SP32Dec2
      Chris
        mptak
        Chris:
        Very Cool Stuff. I'm going to have students in my class start using it when it looks like a few others have succeeded in using 3.2. However, I keep getting a Webdialog is still dirty!!!!!!! message flash to the ruby console often when I make even a minor change to the code changing an if(frame==0) to if(frame==10) for instance. I have noticed and worked around this in the past....you must quit out of sketchup and restart it...but this seems to be more frequent. Any insights. I also will install it on the Mac side (I am running windows in boot camp) and see if it is any different.
        Many many many kudos!
        ...later that morning on the apple side of a macbook...
        Error starting the simulation: : uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds
        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/ControllerCommands.rb:777:in `initialize'
          CPhillips
          I dont seem to have the problem with the dirty dialog message. Can you give me some steps to reproduce it? Also does it act broken or just display a message?
          I'll look into the Mac problem.
            driven
            %(#0040BF)[Error Loading File sketchyphysics.rb
            dlopen(/Library/Application Support/Google SketchUp 8/SketchUp/plugins/SketchyPhysics3/sdl/SDL_Special.dylib, 9): no suitable image found. Did find:
            /Library/Application Support/Google SketchUp 8/SketchUp/plugins/SketchyPhysics3/sdl/SDL_Special.dylib: unknown required load command 0x80000022]
            do you know what this means
            john
            also get this if I attempt to proceed
            %(#BF0000)[Error starting the simulation: : uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/ControllerCommands.rb:777:in `initialize']
              mptak
              It could be an issue with my machine so I will get back to you after I have tried an install on a few other machines and then send some examples if it persists. Good luck with the Apple side. I see a confluence of mystical powers to higher math and modeling understanding when you can mix Apple Grapher with SP....(even though I know the original Apple Grapher is now Pacific T. Cheers!
              • P Offline
                phy
                @mptak said:
                Chris:
                There is a work around for the "Webdialog is still dirty" message. After you make a change to your code, click on the sketchyphysics inspector before closing it. If you don't the next time you open the inspector it will give the "Webdialog is still dirty" error.
                Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                  CPhillips
                  That helps a little. Now if I could just figure out how to get this to start happening I am sure I could fix it.
                  @phy said:
                  @mptak said:
                  Chris:
                  • W Offline
                    willeykj
                    john
                    Typically this means that the OS attempting to load (dlopen) the dynamic library is not compatible with the library (either architecture or 32-64 bit mismatch).
                    I need to know what version of OX X you're running. The best bet is 10.6 on a newer intel box but it should work on any intel mac after 10.4 I would think.
                    Please drop me a note with the specifics of your mac or post something here and I'll take a look.
                    Kevin
                    • P Offline
                      phy
                      I couldn't quite interpret what you mean there. Do you mean you can't reproduce the problem?
                      If so, add or change some script on a simple model and straightway exit the sketchyphysics inspector.
                      You see the inspector doesn't make the change to the script until you take the focus off of the text area.
                      If you x out of the inspector before taking the focus off the text area the webdialog gets dirty.
                      Hope I make sense.
                        solodown
                        dlopen(/Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL_Special.dylib, 9); no suitable image found.  Did find;
                        	/Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL_Special.dylib; unknown required load command 0x80000022
                          CPhillips
                          It looks like right now SketchyPhysics will only work on Mac's running 10.6. We may be able to make a 10.5 version if there is enough demand. Can a few mac users chime in and let me know if you are still using 10.5. Also is anyone using 10.6 getting this error?
                          Chris
                            solodown
                            Mac OS X 10.5.8
                              mptak
                              Spent a few minutes Christmas morning installing SP3.2 on my triplet nephew's Macbook with SnowLeopard and it worked nicely...I guess it is time to upgrade to snow leopard....Adapt or perish I guess.
                                jblively
                                • New script command setFrameRate overrides physics settings framerate.
                                Hello, trying to implement the set frame rate command to get the model to slow down on faster computers so we can anticipate the results.
                                Can you let me know the usage and where to put it.
                                I've tried setFrameRate=5; in the on tick section and it doesn't seem to make any difference.
                                Thanks,
                                Joe
                                  bossdave
                                  I am running SU8 with wine on Ubuntu with SP3.2. The UI box appears showing: Joint, State, Properties, Shapes , but no details. Same problem withSP3.1. Any ideas what I am missing? Thanks
                                  • P Offline
                                    phy
                                    There you go http://forums.sketchucation.com/viewtopic.php?f=61&t=33030
                                    webdialogs don't work in wine without this tweak.
                                      CPhillips
                                      Thanks,
                                      Joe
                                      Thats not quite how it works. a frame rate of 5 will make the physics simulation step 5 times before updating the sketchup model. To make it go a little slower you could use a frame rate of 1.
                                        MichaelG.1
                                        I posted a comment
                                        [more particularly a plea for help]
                                        in the newbie forum, yesterday.
                                        Grateful for any assistance.
                                        MichaelG.
                                        Update: 01-01-2011
                                        ... Having received no response. I finally discovered that my download of SP3.2 was either incomplete or corrupt.
                                        Now, having downloaded a fresh copy, everything seems to work.
                                        • robintR Offline
                                          robint
                                          help UI window not working
                                          Postby robint on Mon Jan 03, 2011 8:59 am
                                          ive got su8 latest and sp 3.2 installed
                                          when I try to inspect joints i get the usual info for a hinge (say). when I try to input say accel or a controller name , it accepts them but doesnt do anything - no slider in the run panel
                                          Ive tried the other tip of clicking on the UI button to exit the UI window to no avail
                                          I saw a tuorial where it said that you can turn a hinge into a reversible motor by putting accel = 1 and giving the controller a name - which is then supposed to bring up a slider in the run panel - i just get a blank.
                                          then i go back and look again and just get blank boxes. only restarting su8 will clear the prob but it comes back if I try to change a parameter
                                          cheers Robin
                                          ps I havent got so excited since I first used SU4 - this could be a wonderful educational tool if physical values could be added to demonstrate newtons laws for example
                                          I made a double pendulum the other day, but as already said, there's lots of real world physical attributes to be addressed (eg mass, density, friction, elasticity etc) but its early days
                                          As one door closes another one slams in your face
                                          • robintR Offline
                                            robint
                                            Hi guys
                                            how or where do I post a skp model for discussion
                                            also i cant post a link here?
                                            robin
                                            • 1 / 3
