    Looking for a line extension plugin
    5 Posts 3 Posters 669 Views 3 Watching
    • brodieB
      brodie
      There seem to be a number of extension plugins out there, most of them I haven't tried. Is there a plugin solution that would basically extend two lines to meet eachother (sort of like autocad's fillet tool if you use it with a 0" radius)?
      Here's a quick before and after of what I'd be looking for...
      -Brodie
      • L
        lapx
        hello Brodie,
        I think ktools does what your are looking for: Ktools, geometry, roundedge. Set raduis to zero.
        • J
          Jim
          I'll second this - I could use a stand-alone extend/trim and maybe fillet that fits in the "SketchUp Way" of working.
          Well, trim might not make sense since intersecting lines already break and just need erased.
          1. Activate Tool
          2. Select Extend or Fillet mode. Default to last used.
          3. Optionally enter length/radius values in VCB. Default to last used.
          4. Select 1st Line
          5. Select 2nd line
          6. Selection clears, Repeat from step 3.
          • brodieB
            brodie
            got a link for ktools?
            -brodie
            • L
              lapx
              See link:
              http://rhin.crai.archi.fr/RubyLibraryDepot/plugins_list_az.php
