    Testing user input as valid geo-location
    7 Posts 4 Posters 432 Views 4 Watching
    • honoluludesktopH Offline
      honoluludesktop
      I tried to test UI.inputbox to validate the user_input location:
      result=shadowinfo["City"]=user_input
      The API is as follows:
      ShadowInfo.[=
      The set value []= method is used to set the value in the array of shadow info options.
      Arguments:
      key The key of the shadowinfo value to set.
      value The value to be set.
      Returns:
      value the value that was set if successful, or false if unsuccessful.]
      When the user_input is a bogus location, the value (return) is not false but the bogus location. The resulting longitude, and latitude are from the previous correct location.
      Am I doing something wrong? What method can be used to test the user_input for a real geo-location besides a convoluted test of previous against new longitude, and latitude?
        You're using the assign operation = instead of the evaluation operator ==
        result == (shadowinfo["City"] == user_input)
        (I'm not sure if the brackets are required to correctly evaluate that line, so I add it for safety and readability.)
          honoluludesktop
          This is going to take time, I can't get the code to work.
            result = (shadowinfo["City"] == user_input)
            πŸ˜„
            There!
            πŸ˜• 😳
              Jim
              Thom made a very similar typo in his example. Should be:
              • Dan RathbunD Offline
                Dan Rathbun
                ShadowInfo.[=SketchUp
                Delete the word "Sketchup" (you got it from the righthand version column. It's not part of the text.)
                I'm not here much anymore.
                  honoluludesktop
                  Done, Thanks Dan. 😳
                  Haven't gotten back to working on this part of the code yet.
