    Help!
    3 Posts 2 Posters 346 Views 2 Watching
    • B
      Builder Boy
      I made this code in the Web Console
      model = Sketchup.active_model
      entities = model.active_entities
      selection = model.selection
      if selection.empty?
        UI.messagebox("No Selection")
      else
       prompts   = ["X", "Y", "Z"]
       defaults  = ["1.0", "1.0", "1.0"]
       list      = ["", "", ""]
       input     = UI.inputbox prompts, defaults, list, "Size"
        group = entities.add_group selection
       if (group)
        selection.add group
       else
        UI.messagebox "Failure"
       Xsize = input[0].to_f
       Ysize = input[1].to_f
       Zsize = input[2].to_f
       e = selection[0]
       tr1 = e.transformation
       tr2 = Geom;;Transformation.scaling(Xsize, Ysize, Zsize)
       e.transform!(tr1.inverse)
       e.transform!(tr2)
       e.transform!(tr1)
       status = group.explode
      But, every time I run the script, I get this message in the ruby console:
      warning; already initialized constant Xsize
      warning; already initialized constant Ysize
      warning; already initialized constant Zsize
      How do I fix this?
      All my plugins
      • dereiD
        derei
        How do I fix this?
        Well, for start, you could type in lowercase πŸ˜„ Because if your variable name starts with capital letter, ruby takes it as CONSTANT. You are lucky that ruby lets to redefine constants, most of programming languages don't allow πŸ˜„. This is why you get the warning.
        use something like this, it's easier to read and those are local variables, not constants:
        x_size = input[0].to_f
        y_size = input[1].to_f
        z_size = input[2].to_f
        DESIGNER AND ARTIST DEREI.UK
        • B
          Builder Boy
          Thanks! it works perfectly now!
          All my plugins
