    Streetscape
    26 Posts 12 Posters 4.4k Views 12 Watching
      davidh
      Attached is an image of a streetscape.I hope to upload a night shot later,with some additional planting.
      • boofredlayB Offline
        boofredlay
        Very nice. Is there no slope from the drive to the roadway? I think there are too many cars in that image also.
          davidh
          The same scene but rendered with a HDRI .There is no slope from the driveway,its at the same level as the footpath.
          • EarthMoverE Offline
            EarthMover
            I think Eric is asking if there is a dip in the curb line at each driveway. I doubt the homeowners want to jump the curb to pull into their driveway.
            Great modeling by the way. As usual, your scene looks alive. Great use of foreground shadowing in the first one. The HDRI one looks a little flat. I like HDRI's for fill/ambient light, but still using a sun/light source for crisper shadowing.
            Content Creator at Skapeup
              davidh
              ligts added and pavement corrected at gate.the render on the side of the house needs some additional specularity in order to really catch the light from the HDRI.
                davidh
                Ive reattached 2 of the images with updated materials and lighting,I noticed that some of the glass on the cars was incorrect.
                • mitcorbM Offline
                  mitcorb
                  Nice work. Very convincing.
                  Must be a wireless community 😉
                  • Mike LuceyM Offline
                    Mike Lucey
                    Nice work David, very convincing indeed. Looks to me to be an English suburb scene with 30+ year old houses, thus the need for a high number of cars in the scene. The families now are two car families whereas back thirty years ago it was just a one car per family situation! They never envisaged that families would own two cars 😮
                    Just a nip pick! In relation to the kerb dishing mentioned by Eric. A full kerb approx. 1m long would normally be used for the 'dish'. This would allow an easy slope thus helping to avoid 'compo claims' 😉
                    Mike
                      davidh
                      one more
                        davidh
                        2 more renders.the sunset was rendered in thea,the wet stretscape in vray.I'll have to revise the kerbing as it is too sharp and is distracting.All the views are from the same vantage point but with different lighting etc.This helps because the planting is all on one photoshop layer and can be dragged onto each image and so consequently is in the same place and all that is required is to play around with saturation etc.,depending on the main image lighting.
                        sunset
                        after the rain
                          sepo
                          Apart from kerbs these are great renders, both Thea and Vray. I suggest you introduce kerbs as separate elements. I do not know where this is in UK but most of old kerbs are made of granite. You should decide if pavement is tarmac or some sort of paving slabs and than add drop kerb accordingly. Being stickler (sorry) I would add car plates. 😄
                          • cucsat2003C Offline
                            cucsat2003
                            wow,I love the illuminations!!!very impressive.
                            did you use hdri for the exterior lighting?can you share some tips how to get that exterior lighting effects?
                              davidh
                              Revised images with the pavement kerb corrected and internal lighting reduced.
                              The first image is lit with an HDRI.In order to get a good quality light from an HDRI,you need to use quite a large size image.this one is 120mb.you can use a smaller size and increase the multiplier but you will not get the same quality.
                                Sir
                                that second image is fantastically lit. one of the most realistic sunset lighting ive ever seen. the only thing that lets it down is the low poly cars, the houses are totally believable
                                • pyrolunaP Offline
                                  pyroluna
                                  Yes. And the fact that the cars don't have license plates. That's a dead give-away that it's a render. And of course the perfect angle of the photograph... you're standing in the middle of the road; that's plain dangerous!
                                  • mitcorbM Offline
                                    mitcorb
                                    Some states/provinces/principalities/whatever, may not require front plates on vehicles.
                                    • pyrolunaP Offline
                                      pyroluna
                                      I see now that you had 'm at first on the VW's but not on the Volvo, and I remember at the time when seeing the first picture, I was wondering 'why does the volvo look so unnatural'. Now I know. The Volvo looks naked without a license plates. The VW's however, do not, since the model is designed to look good with or without them. Also, the metallic band helps.
                                        sepo
                                        In the UK both front and rear plates are mandatory.Front plates white and rear yellow.
                                          When I studied in Pennsylvania, there front plates were not required (but you were only allowed to park you car with the rear out to the street in a parking lot).
                                          • pmolsonP Offline
                                            pmolson
                                            Very Impressive! Nice attention to detail and the lighting
                                            is just fantastic.
                                            Paul
                                            • 1 / 2
