    Streetscape
    26 Posts 12 Posters 4.0k Views 12 Watching
      davidh
      2 more renders.the sunset was rendered in thea,the wet stretscape in vray.I'll have to revise the kerbing as it is too sharp and is distracting.All the views are from the same vantage point but with different lighting etc.This helps because the planting is all on one photoshop layer and can be dragged onto each image and so consequently is in the same place and all that is required is to play around with saturation etc.,depending on the main image lighting.
      sunset
      after the rain
        sepo
        Apart from kerbs these are great renders, both Thea and Vray. I suggest you introduce kerbs as separate elements. I do not know where this is in UK but most of old kerbs are made of granite. You should decide if pavement is tarmac or some sort of paving slabs and than add drop kerb accordingly. Being stickler (sorry) I would add car plates. ๐Ÿ˜„
        • cucsat2003C Offline
          cucsat2003
          wow,I love the illuminations!!!very impressive.
          did you use hdri for the exterior lighting?can you share some tips how to get that exterior lighting effects?
            davidh
            Revised images with the pavement kerb corrected and internal lighting reduced.
            The first image is lit with an HDRI.In order to get a good quality light from an HDRI,you need to use quite a large size image.this one is 120mb.you can use a smaller size and increase the multiplier but you will not get the same quality.
              Sir
              that second image is fantastically lit. one of the most realistic sunset lighting ive ever seen. the only thing that lets it down is the low poly cars, the houses are totally believable
              • pyrolunaP Offline
                pyroluna
                Yes. And the fact that the cars don't have license plates. That's a dead give-away that it's a render. And of course the perfect angle of the photograph... you're standing in the middle of the road; that's plain dangerous!
                • mitcorbM Offline
                  mitcorb
                  Some states/provinces/principalities/whatever, may not require front plates on vehicles.
                  • pyrolunaP Offline
                    pyroluna
                    I see now that you had 'm at first on the VW's but not on the Volvo, and I remember at the time when seeing the first picture, I was wondering 'why does the volvo look so unnatural'. Now I know. The Volvo looks naked without a license plates. The VW's however, do not, since the model is designed to look good with or without them. Also, the metallic band helps.
                      sepo
                      In the UK both front and rear plates are mandatory.Front plates white and rear yellow.
                        When I studied in Pennsylvania, there front plates were not required (but you were only allowed to park you car with the rear out to the street in a parking lot).
                        • pmolsonP Offline
                          pmolson
                          Very Impressive! Nice attention to detail and the lighting
                          is just fantastic.
                          Paul
                            cucsat2003
                            @ Davidh: when I try HDRI for my renderings,I can't control the size and position of it,so I can't control the reflection,backgrond and shadow in my renders.Do you have any tricks of using HDRI?or just drop HDRI map into GI and Background.
                            Hope you can help โ“ โ“ โ“
                              davidh
                              When I am trying to locate the HDRI into position,what I normally do is load the HDRI and then hide all parts of the model,then render at about 640x420.because no geometry is being rendered,it takes very little time to render,normally 10 -20 seconds, and you can see straight away if you have to rotate it.Regarding shadows,you will only get strong shadows if you have a bright spot in the HDRI.As I said before,in order to get a good quality light from an HDRI,you need to use quite a large size image.You can use a smaller size and increase the multiplier but you will not get the same quality.
                              I normally use a HDRI for lighting at dusk shots.If you are using a HDRI for a dusk/early night shot it is good to get one that has a blue tinge to it,as even when it is totally dark,the sky colour is blue,not black.
                              (I have uploaded the image with car plates added)
                                john.warburton
                                Really looking good. Lighting spot on. Just a little bit of dirt (especially to the road and footpath) and you'd have nailed it totally.
                                Life's a reach, and then you gybe.
                                • pyrolunaP Offline
                                  pyroluna
                                  There's always something more to make it even more realistic...
                                  I think it's great already!
                                    sepo
                                    Beautiful dusk light. ๐Ÿ‘
                                      cucsat2003
                                      thank you very much,Davidh,it's work!really helpfull for me ๐Ÿ˜„
