    Follow me tool
    5 Posts 2 Posters 1.6k Views 2 Watching
      rokahljr
      I am having difficulty placing a molding into a recessed panel by using the follow me tool. I insert a profile onto the edge, draw a line for the follow me tool to follow, but it doesn't bend 90 degrees inside the corner.....any help would be appreciated.
        I'd be happy to help but I'd like to see what you're trying to do.
          rokahljr
          Hi Dave...I have attached a file regarding the problem I am having with the follow me tool. Inside the panel, I want to insert a decorative molding. What I have tried was drawing a 2d profile on the edge and trying to extrude it using the follow me too along the inside of the panel. Can't seem to get it to work. I'd appreciate any help you can give me.
          followmetest.skp
            Bob, I'm just leaving for home and I'll look at it when I get there and get back to you. Should be within 30 minutes or so.
            Dave
              Bob,
              So your file shows a frame (without a back). Do you want the molding to be a separate component from the frame? I assume so. To get Follow Me to work with a profile outside the frame component, you'll also need a path that is outside the frame component. The simple way to do this is to draw a rectangle to fit inside the frame. Just click on diagonally opposite corners with the Rectangle tool. I would delete the face of the rectangle because it isn't needed. Draw the Molding profile on the inside of the frame. Put it along one of the sides, maybe at the midpoint. You can run Follow Me two different ways, I prefer to select the path first, then get the tool and click on the profile. If it makes it easier, hide the frame component before you start selecting the edges of the rectangle for the path.
