    Transformation in scale
    6 Posts 3 Posters 499 Views 3 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Can a transformation in scale be performed on a definition?
      Where t is a transformation making a bunch of entities 12 times bigger:
      #this enlarges my_instance my_definition = my_instance.transform!(t).definition repeat = false #this remains at the original size model.place_component my_definition, repeat
      I thought the first line above creates my_definition of the transformed my_instance, but it doesn't. How do I change the size of my_definition?
        #this enlarges my_instance my_definition = my_instance.definition my_definition.entities.transform!(t)
          honoluludesktop
          Attached error message with the example:
          I looked up entities, and tried the following. It runs, but without transformation to my_definition.
          my_definition = my_instance.definition my_definition.entities.transform_entities (t,my_instance) model.place_component my_definition
          Have been working on this off and on, for a couple of days. Something else must be going on????
          • Chris FullmerC Offline
            To scale a definition, I think you have to scale its entities. The definition has to be at scale 1.0 I would guess. So to get it to be larger, scale all its entities.
            All my Plugins I've written
              Sorry - posted in a rush - but you very nearly got there.
              my_definition.entities.transform_entities(t,my_definition.entities)
              (Avoid spaces between the methods name and the brackets)
                honoluludesktop
                tt, and cf, Thanks. Got it to work as follows:
                my_definition.entities.transform_entities(t,my_definition.entities.to_a)
                Off and on for 4 days, this has got to be the longest time I've spent getting a single line of code right. Hopefully I'm getting better.
