    Call for attention - context handlers and validation procs
    24 Posts 10 Posters 34.7k Views 10 Watching
      I hope the various scripters here can take a moment and look into this.
      While working on a large siteplan where I had ~200-300K edges I noticed that when I had selected everything and right-clicked SU would freeze up for several seconds before poping up the window. Often the SU window would flicker as it returned to a responsive state and cause the right click menu to disappear.
      I tried with all plugins disabled and found that there was then no lag at all.
      It occurred to me that some plugins might be trying to process the whole selection in the context handler. Checking my own plugin I found Selection Toys to do so - which of course is a naught thing to do. I modified it so it'd only inspect the selection if the selection was less than 1000 entities. When the selection is over 1000 it makes the assumption that the selection can contain anything and display all menus.
      That cut down the lag a little, but there's still many seconds lag. So there is more plugins. Initial scan of my plugins I found no more, so now I ask the rest of you to review your context menu handlers.
      And I expect one should be just as careful when it comes to validation procs. (I'm a wee bit unsure to exactly when these triggers - as toolbar buttons also can have these.)
      Summary:
      Don't process the whole selection in context handlers or validation procs. Place size limitations or remove the validation all together.
      Test the right click menu and it's performance on large models with large selections when adding context handlers.
      Debug Script for Benchmarking
      Ensure this loads before all other plugins.
      Open the Ruby Console, when right-clicking performance data will be outputted.
      To list all attached handlers:
      TT.list_context_handlers
      • tbdT Offline
        tbd
        maybe we should create a checklist for releasing ruby scripts, something like http://lite.launchlist.net
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
          I think that would be a good idea. πŸ‘
          • AdamBA Offline
            AdamB
            I'm half finished with a plugin called "Snitch" which collates the time each plugin's Observers take so we can start pointing fingers.
            Guidelines are fine, but witchhunts / naming and shaming has much better results. πŸ˜„
              How do you manage to track other observers?
              Can it be translated into validation procs and context handlers?
              • Chris FullmerC Offline
                Woohoo!, let the games begin. I have a feeling I'm gonna score big!!!! (I hope its good to score big πŸ’š )
                All my Plugins I've written
                  http://static.tvtropes.org/pmwiki/pub/images/torches_and_pitchforks.jpg
                    uh... both maybe πŸ˜„
                    [flash=640,385:2c4nksvr]http://www.youtube.com/v/zrzMhU_4m-g?fs=1&hl=en_US[/flash:2c4nksvr]
                    • honoluludesktopH Offline
                      honoluludesktop
                      Are the witches hunting, or are we hunting witches?-)
                      Don't know what the following has to do with this topic, but it seemed like the thing to do:-)
                      http://www.google.com/images?q=tbn;lnizWqr0oVMvhM;;www.wyldeart.com/Galleries/Expressionist/Edvard_Munch/Images/TheScream1Up.jpg&t=1&h=196&w=148&usg=__v8o0X36oacv_3bHuA0QFQ6a4ucw=
                        honoluludesktop
                        That's rich! The opening scene strikes a cord, it's me writing an app:-)
                          I made a little sniffer script that will log the scripts that creates context handlers. Lets one easier inspect which scripts are adding context handlers.
                          I found xLine to be processing the whole selection. I'll be looking further into what scripts have inefficient context handlers. At the moment it takes many seconds for me when I right click a large set of selected entities.
                          (Removed - See first post)
                          Type TT.list_context_handlers to get a list of attached context handlers in the Ruby Console.
                            I just updated the first post with the debug script - it now benchmarks the handlers, outputting the time they take to process to the Ruby Console.
                              Sample output for a selection of about 100K entities:
                              ### Context Handler ### 2D#loader.rb:181:inactivate' 2D#.rb:44
                              0.0 seconds
                              Context Handler
                              bezier.rb:501 [...] bezier.rb:501
                              0.006 seconds
                              Context Handler
                              parametric.rb:320 [...] (eval):2696
                              0.0 seconds
                              Context Handler
                              (eval):103:in `load' [...] pb_loader.rb:9
                              0.0 seconds
                              Context Handler
                              tt_bitmap2mesh.rb:29 [...] tt_proxy_loader.rb:28
                              0.0 seconds
                              Context Handler
                              tt_image_opacity.rb:30 [...] tt_proxy_loader.rb:28
                              0.0 seconds
                              Context Handler
                              ui_manager.rb:261:in `build_ui' [...] tt_selection_toys.rb:240
                              0.004 seconds
                              Context Handler
                              xLine.rb:51 [...] xLine.rb:51
                              0.0 seconds
                              Context Handler
                              Lib6Plugin.rb:656:in `build_config_handlers' [...] ZLoader__FredoScale.rb:24
                              0.0 seconds
                              Context Handler
                              Lib6Plugin.rb:656:in `build_config_handlers' [...] ZLoader__OnSurface.rb:26
                              0.489 seconds
                              Context Handler
                              (eval):299:in `initialize' [...] dynamiccomponents.rb:38
                              0.0 seconds
                              Context Handler
                              webtextures_loader.rb:886 [...] webtextures.rb:22
                              0.0 seconds
                              Context Handler
                              bezierspline_main.rb:2413:in load_all_menus' [...] extensions.rb:36:in load'
                              5.657 seconds`
                              (Note I had modified xLine and Selection Toys prior to this test)
                              • fredo6F Offline
                                fredo6
                                Context Handler
                                bezierspline_main.rb:2413:in load_all_menus' extensions.rb:36:in load'
                                5.657 seconds[/ruby]
                                I fixed the one for BezierSpline, with an upgrade.
                                see http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&p=100509#p100509
                                Fredo
                                  πŸ‘
                                  • P Offline
                                    Pout
                                    Reminds me of something simular I seem to have in big models when rightclicking a material.
                                    The rightclick window just doesn't pop-up
                                      Yea - I've noticed that too. Very annoying. But that menu isn't accessible to ruby plugins. So I think that one is on Google's shoulders.
                                        Jim
                                        Context Handler
                                        Fredo
                                        Bezierspline_main is still sort-of slow for me - it takes 8 seconds for the context menu to pop-up for 75,000 selected entities. (I admit to having a sub-standard pc.)
                                        • fredo6F Offline
                                          fredo6
                                          Jim,
                                          I made a change in the script.
                                          see main post on BezierSpline
                                          Is is better with this release
                                          Fredo
                                            πŸ‘
                                            • 1 / 2
