    Auto Reload Plugin folder
    4 Posts 2 Posters 1.9k Views 2 Watching
      Morgan74
      Hello,
      Thanks to Jim's topic http://forums.sketchucation.com/viewtopic.php?f=180&t=31394 I wrote a plugin to reload a complete folder.
      You define the folder to check and you can define some ignored files.
      When the LastModificationDate change SU reload the file.
      If an error occurs, a messagebox is displayed with the error message with a retry buton.
      My module name is Morgan74DevTools so to start the plugin just call "Morgan74DevTools.startAutoReload()" from the console, from your code or uncomment the last code line.
      module Morgan74DevTools
        Folder = "plugins/Morgan74"
        IgnoredFiles = ["Morgan74ToolLoader.rb","Morgan74Tools.rb"]
        @timer = nil
        @fileList = []
        @fileDate = []
        def self.startAutoReload()
          folder = Sketchup.find_support_file(Folder) #find folder
          @fileList = Dir.entries(folder) #find files
          #remove sub-folders & Ignored files
          to_delete_list = IgnoredFiles
          @fileList.each do |f|
            if File.directory?(File.join(folder,f)) == true
              to_delete_list.push(f)
          to_delete_list.each do |f|
            @fileList.delete(f)
          #concat folder and files
          @fileList.collect! {|f| File.join(folder,f)}
          #Save last modification Date
          0.upto(@fileList.length()-1){|i|
            @fileDate[i] = Kernel.test(?M,@fileList[i])
          self.startTimer()
        def self.startTimer()
          #Start Timer
          @timer = UI.start_timer(2, true) do
            self.AutoReload()
        def self.stopAutoReload()
          UI.stop_timer(@timer)
        def self.AutoReload()
            if Kernel.test(?M,@fileList[i]) != @fileDate[i]
              begin
                Sketchup.set_status_text("Loading ; " + @fileList[i].to_s(),SB_PROMPT)
                load @fileList[i]
              rescue Exception => e
                #Stop timer
                msg = "AutoReload Plugin\n\n"
                msg << "Error loading file ;\n" + @fileList[i].to_s() + "\n\n"
                msg << "Error message ;\n" + e.message + "\n\n"
                msg << "Fix the error before click RETRY or CANCEL to stop the plugin"
                result = UI.messagebox(msg,MB_RETRYCANCEL)
                self.startTimer() if (result == 4)#Retry = restart timer
      #Morgan74DevTools.startAutoReload()
      Next step can be reload all the folders inside the plugin folder.
        Morgan74
        Here is an example of the error message :
        http://lh5.ggpht.com/_6btJdjutpH4/TKwn8qi67AI/AAAAAAAACMI/tWAdzkZTxPM/s800/Error.PNG
          Would help if it included the traceback message so one know exactly where the error occurred.
            Morgan74
            The traceback is always the same with this plugin because the lastest method used is "load" :
            ["C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Morgan74DevTools.rb:48:inload'", "C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Morgan74DevTools.rb:48:in AutoReload'", "C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Morgan74DevTools.rb:44:in upto'", "C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Morgan74DevTools.rb:44:in AutoReload'", "C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Morgan74DevTools.rb:35:in startTimer'", "C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Morgan74DevTools.rb:34:in call'"]
            But you have in the error message the line of the error and a "small" description :
            http://lh5.ggpht.com/_6btJdjutpH4/TKw-MbBTbgI/AAAAAAAACMQ/CiQ9UrtbW9A/s800/Error2.PNG
