    Reception Desk...
    6 Posts 5 Posters 693 Views 5 Watching
      Ross Macintosh
      Rendered with the current beta of the Render[In] plugin. As you can see they fixed the smoothness issue of the first beta release.
      The design is a glass & stainless steel reception desk "front" that could be attached to a standard steelcase desk. It was for an aerospace firm that had the capability to do all the stainless steel machining in-house. The intent was they would put a logo in frosted vinyl on the vertical glass panel.
      Regards, Ross
      • mitcorbM Offline
        mitcorb
        Migthy nice 👍
        • olisheaO Offline
          olishea
          cool, i like the horizontal "louvers"....what are the diagonal lines fading in on the floor? is it part of the texture or something?
          oli
            Ross Macintosh
            The lines on the ground are what I call a 'ground effect' created using a transparent png image placed on the ground in SketchUp. The intent is to 'ground' the drawing as I knew I'd be showing the image with a white background. I created a few different png's I use in situations like this. It works well when you have a series of views and you want to assemble a presentation that takes advantage of the white space.
            The horizontal louvres are intended to both provide some screening & be indicative of the turbine blades on a jet engine. The desk was for a company that does complete overhalls on jet engines.
            Regards, Ross
            • boofredlayB Offline
              boofredlay
              Very nice Ross. I like the ground effect as well.
              Were I a receptionist I would be very happy recepting in that desk.
              • daleD Offline
                dale
                Really fine way to take a standard desk and turn it into something quite pleasing. Great stuff Ross.
