    Build Rome
    234 Posts 20 Posters 74.8k Views 20 Watching
      I do a lot of things like that, too. As a general rule, when the inaccuracy is not too big - and it is not "intentional" - , you can just use the same measurements. Like in a building where we found that the buttresses vary between ~98 and ~102 centimetres. There are dozens of them and obviously they are all supposed to be the same size. Such small differences do exist even nowadays with some buildings.
      • F Offline
        fluffy82
        Ok, thanks!
        I already know that the 2m difference is due to re-use of the foundations of an older building, so I'll try to keep that in the model.
        One of the papers I have here claims that some of the other differences (between like 40 and 60cm) are due to either minor landslides or the weight of the roof pushing the walls outwards, but they would have been constructed rather "correct". So I could justify correcting those, as well as anything smaller (mostly in decorations, like niches or the width of windows).
        Cool, I'll correct the plan and start building.
        • H Offline
          Hepf
          And add to all that the fact that a lot of the older plans have drawing and prospection errors. Total stations and GPS are rather recent, and not even those are always used correctly ... I have that sort of problem in the roman villa I am working on, destroyed when Via dei Fori Imperiali was created by Mussolini, in the 1930's. The plan and prospection was made in a hurry, they had just three months to dig and measure, I can't trust the plans the whole way ...
          • H Offline
            Hepf
            And I just found in some nook of my hard disk a column with the capital I posted the other day, here it goes ...
            coloncap.skp
            • F Offline
              fluffy82
              Yes, that's why I didn't want to just scan a plan from a book and draw over the lines.
              Just last week I was finally able to find a copy of Petrignani's measurements. They seem to be quite accurate, a bit too accurate even (hence my problems with off-axis walls etc).
              I cross referenced the plan with some less detailed but more recent measurements, like Macdonald and Finsen, and started drawing (leaving out Dutert since only a very small part of his plan seems to be correct...).
              The best would be to get a hold of the more recent work of the German Institute of Archaeology (DAINST), but those are impossible to get hold of for an amateur like me 😄
              I read about the damage they did to ancient remains constructing the Via dei Fori Imperiali... It's a shame, but we can be glad that some pictures and plans have survived, even if they aren't very accurate. I hope they do a better job now while constructing the subway 😄
              Thanks for the column by the way, I'm sure it'll be useful.
              • H Offline
                Hepf
                I am trying to figure out what Nero's Domus Transitoria might have looked like. I placed the two villas that I suppose were there at the time. Of the center one with the round room, only the part to the left is known by documents. The part to the right stepping down three levels is a supposition, but a rather logical one, if there were baths and a palestra (gym area) you expect also a residential area. It could only be in that direction, and that's on a steep slope, and a rather unstable one too. The villas almost link with the house of the Domitii, that is known by that crosslike hall, supposedly underground also at the time it was built and used (fresh hall in summer). So now I have to imagine what the above ground building might have looked like if, as is very probable, Nero bought the two villas and somehow welded the whole thing somehow ...
                • H Offline
                  Hepf
                  Ok, Csaba won't agree, but I wanted to amuse myself some. I centered the whole building around the circular underground hall, the only known element, and I referred to some paintings from Pompei as a reference. So this is my version of the house of the Domitii as refurbished by Nero before the fire. The main point is that the whole thing happens on a hillside.
                    Why would I not agree? Quite interesting concept! 😄
                    (And though I do not always post/reply, I follow the topic closely)
                    • F Offline
                      fluffy82
                      Looks interesting!
                      Did you get your inspiration partly from the Esquiline wing of the Domus Aurea as well or is it just a coincidence?
                      (the central square you have put over the remains of the so-called "House of the Domitii" reminds me of the pentagonal court, as well as the peristyle on the higher level; the Esquiline wing's first floor also had this pavilion like structure, according to Laura Fabbrini).
                      I like the idea where Carandini puts a similar structure between the artificial lake and the vestibule, though I don't really agree with him placing the "coenatio rotunda" there...
                      About the living quarters: there are many remains of neronian times below the Domus Flavia and Augustana. It is almost certain that Nero built a large reception hall where is now the Aula Regia, and the nymphaeum ("baths of Livia") could have been part of a triclinium, the same concept being reproduced on a larger scale by Domitian.
                      Since the official part of Domitian's Palace is certainly based upon an older neronian lay-out, I like to think that the residential part was as well... Certainly because one of the walls I mentioned earlier, which is 2% out of axis with the rest of the palace, seems to built on foundations older than the rest of the palace, 1st century AD.
                      I am still working on the late phase of the palace (severan/maxentian), once that is done I plan on doing the early flavian phase and have a shot at what the neronian phase could have been... But that's far future 😄
                      • F Offline
                        fluffy82
                        Hey all,
                        I thought I would post some pics of what I'm doing...
                        I didn't render them yet, I prefer to wait until the model is more finished before I start putting textures etc.
                        These are just most of the raw volumes (not quite finished) and the start of some deatils to the hippodrome.
                        A simple lay-out for Augustus' home and the Temple/Precinct/Libraries of Apollo are there, the "Vigna Barberini" will follow after that.
                        Don't hesitate to give comments, remarks, corrections, whatever! Always eager to learn... 😄
                        Tom
                        aerial view
                        bird's eye over the Domus Augustana (private part)
                        one of the fountains next to the Triclinium
                        entrance to the Domus Augustana - I don't know yet if I'll make the porticus continuous like this, or interrupted
                        overview of the hippodrome-garden
                        the hemicycle
                        view from one of the lower galeries in the hippodrome-garden
                        • H Offline
                          Hepf
                          Ok, I am back. Fluffy's model is remarkable. I'd love to have it and stitch it with my work, it would spare me a lot of sweat.
                          I am facing the problem of filling in the gaps, residentrial areas that we don't know much about, and must be somehow be filled with believable buildings. In some cases it's just a matter of putting in generic volumes and cubes, maybe with a roof. But in some cases I'd want to put in some believable buildings, as in the case of the road that goes towards the arch of Constantine. We know it was a straight road, about 11 meters wide, with sidewalks of maybe 4 m., lined with housings with shops at the floor level. I am making some meccano like thing, building blocks that can be assembled. I am posting one of such, and a pic of one of thousands of possible assemblies.
                          domus_3.skp
                          • P Offline
                            pichuneke
                            Some time ago I thought that the Meccano/Lego way is the best for residential buildings.
                            Rome Reborn does that using procedural software. And it's a pity that residential areas are not very well known, as far as I know Rome was the New York of that era, with "skyscrapers" (well, at least considering the time they were built).
                            Meanwhile I am working with the spanish theatres of the XVII century, I hope I can come back soon with my roman models.
                            And I am happy to see you again, hepf. I was wondering where were you. 😉
                            Forgive my spanglish...
                              Not Rome but all Versailles' Casttle and park, gardens were modilized with SU! 😉 All is "Online" ! ☀
                              http://www.versailles3d.com/en/
                              Have fun visit! 😎
                              • micioneM Offline
                                micione
                                Buongiorno Marco,
                                Complimenti per l'imponente lavoro che stai svolgendo.
                                Ti allego un file che magari potrebbe servirti per qualche primo piano .
                                E' solo un umile contributo.
                                I miei più cordiali saluti.
                                Roberto
                                colonna con capitello.skp
                                • H Offline
                                  Hepf
                                  To Pichuneke. Yup, "skyscrapers" are a problem. Nero established a height limit of 21 m. (seven floors) which means that before the fire you had even higher buildings. Usually bricks for the first two floors, and shaky wooden structures going up from there. That didn't happen in the central area, but it did in the shadier neighbourhoods, like the Suburra. I am fond of Gilles Chaillet's work, he usually did a good research, but he got some things wrong. In the plate I show he imagined nice gardens and gazebos on the top floor. That's a modern idea, when you have elevators. In roman times the wealthy lived on the first floor, and poorer and poorer people going up. The really miserable lived on the top floor, had to carry water and things up there through shaky stairs, and were practically condemned to death in case of fire.
                                    Seems the comic's image is very near from Alix by a French guy Jacques Martin (1948) a pioneer! 😉
                                    Gilles Chaillet was assigned by Jacques Martin the resumption of drawings of the adventures (1976) under his direction
                                    Documentation is from Jacques Martin 😉
                                    • P Offline
                                      pichuneke
                                      I knew it, hepf. Julius Cesar was born in one of those buildings. Am I right? At least I read it in a novel. Cerdá, the spanish urbanist that made the famous "ensanche" (enlargement) of the city of Barcelona, considered that, as there were not elevators in the XIX century, the buildings would help to the integration of the different social classes. In the first floor the richest, at the top floor the poorest. But as all the neighbors would see themselves every day, they may mix (the son of the rich marries the daughter of the poor in the same building).
                                      • H Offline
                                        Hepf
                                        Grazie per la colonna, Micione.
                                        Yes, the comic image is Alix, but Chaillet is the artist and researcher on roman architecture.
                                        This is a first try of the shops in front of the Coliseum. Probably the entrance to the side road to the right was monumentalized with an arch or something ...
                                        • H Offline
                                          Hepf
                                          Another set, that I'll probably use for the road that goes up to the arc of Constantine (Via Gregoriana) ...
                                          ostia.skp
                                          • H Offline
                                            Hepf
                                            That's what it looks like ...
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 9 / 12
