    Build Rome
    234 Posts 20 Posters 91.8k Views 20 Watching
      pichuneke
      @hepf said:
      @pichuneke said:
      ... continue working on my roman theatre. I have a problem with those corinthian capitals...
      I don't know if it can help, but I made up a very simplified one for the Pantheon, and I think it looks good ...
      The model of the pantheon needs an explanation, it is not as it is, but as it was planned. The king size columns didn't arrive in time, so they had to settle for lower ones, that's why the actual entrance looks a bit squat. This is what it was meant to be.
      Thanks hepf, I have downloaded it, I may adapt your capitals for the theatre. The game engine needs optimized models, and my original capitals are very complex. Although I believe you don't know about it, if you put a normal or bump map texture over a simplified model, you can simulate a very complex 3D model with a low amount of polygons (in Kerkythea, a game engine...). That's what I am trying to do, but it's slow...
      You have an example here: http://www.messiahdesigns.hurm3d.com/images/2d/chariotscene.jpg You haven't started yet to texture your models, it's time consuming but gives you the realistic touch, more detail. As you are studying the urbanism of the ancient Rome, you don't need to reach that level.
      Forgive my spanglish...
        @pichuneke said:
        @gaieus said:
        Pichuneke: this game like walkthrough is also exactly what I am planning to achieve (in the long run) with out World Heritage site. Both the visitor centre (as it is today - with the ruins in there) and the reconstructed stuff.
        P.M. If I can help you let me know, send me a private message.
        Well, currently I am using Lumion to put together very large scale models with lots of buildings. I now allows for stills and movies but a walkthrough kind of export will also be available at a time (as well as some panoramic output which true that gives another kind of experience but can be used to show some things nicely).
        We1ll see where we get with it.
        • H Offline
          Hepf
          I do use bump maps, but in Poser. There goes Pichuneke's chariots ...
            pichuneke
            They are not mine. Anyway I am going to start working on something... hepf, I will send you a Private Message later 😉
            • F Offline
              fluffy82
              lol I'm getting depressed seeing your work being fantastic, and then seeing my crappy work on the Palatine next to it, starting over for the 5th or 6th time.
              I really need to convince myself to try not to be too detailed... It would be great to use your corinthian capital in stead of hamernhanks and karlfucious' I found on the warehouse. They're beautiful, but just too big to handle (including the Apollo precinct there are more than 300 columns in the model...). I'm sure you'll say I can, but I always prefer to ask 😄
              In any case, I don't think my model will ever get finished and certainly not published anywhere ^^
              Regards,
              Tom aka fluffy
              • H Offline
                Hepf
                To Pichuneke and Fluffy82. Of course you can (link my animation or use my capitel). I am not by any means jealous about my work ...
                • F Offline
                  fluffy82
                  I have a rather strange question for all of you...
                  When you make models, which do you esteem more important? Accuracy or beauty?
                  Trying to make a model of the Palatine palaces, I just came across a very detailed plan of the remains by Petrignani. I started over for the 5th or 6th time, laying out the ground plan following his measurements (keeping in mind a small error margin and the absence of wall decoration, which adds thickness to the walls as well). But I came to the conclusion that many features which are supposed to be symmetrical really aren't. A couple of centimeters can be corrected without anyone noticing it, but some of the features are between 40cm and 2m out of axis (which is really visible in the model, and hell for constructing the actual walls).
                  It would be easier to ignore any imperfections and make a "perfect" model (at least 1/3 can be made by copying and/or mirroring another part, reducing the file size as well), but it won't be "correct"...
                  I can't decide on which way I should take, any comments or advice are absolutely welcome 😄
                  Tom
                    pichuneke
                    Tom
                    There is not perfect construction. A small error of few centimetres... I ignore them. Those errors came usually due to a lack of precision when build. But 40 cm, 2 m... there must be important reasons for that. Perhaps the evolution of the building. But I think that's relevant and must be included.
                    Of course, it's a personal election.
                      I do a lot of things like that, too. As a general rule, when the inaccuracy is not too big - and it is not "intentional" - , you can just use the same measurements. Like in a building where we found that the buttresses vary between ~98 and ~102 centimetres. There are dozens of them and obviously they are all supposed to be the same size. Such small differences do exist even nowadays with some buildings.
                      • F Offline
                        fluffy82
                        Ok, thanks!
                        I already know that the 2m difference is due to re-use of the foundations of an older building, so I'll try to keep that in the model.
                        One of the papers I have here claims that some of the other differences (between like 40 and 60cm) are due to either minor landslides or the weight of the roof pushing the walls outwards, but they would have been constructed rather "correct". So I could justify correcting those, as well as anything smaller (mostly in decorations, like niches or the width of windows).
                        Cool, I'll correct the plan and start building.
                        • H Offline
                          Hepf
                          And add to all that the fact that a lot of the older plans have drawing and prospection errors. Total stations and GPS are rather recent, and not even those are always used correctly ... I have that sort of problem in the roman villa I am working on, destroyed when Via dei Fori Imperiali was created by Mussolini, in the 1930's. The plan and prospection was made in a hurry, they had just three months to dig and measure, I can't trust the plans the whole way ...
                          • H Offline
                            Hepf
                            And I just found in some nook of my hard disk a column with the capital I posted the other day, here it goes ...
                            coloncap.skp
                            • F Offline
                              fluffy82
                              Yes, that's why I didn't want to just scan a plan from a book and draw over the lines.
                              Just last week I was finally able to find a copy of Petrignani's measurements. They seem to be quite accurate, a bit too accurate even (hence my problems with off-axis walls etc).
                              I cross referenced the plan with some less detailed but more recent measurements, like Macdonald and Finsen, and started drawing (leaving out Dutert since only a very small part of his plan seems to be correct...).
                              The best would be to get a hold of the more recent work of the German Institute of Archaeology (DAINST), but those are impossible to get hold of for an amateur like me 😄
                              I read about the damage they did to ancient remains constructing the Via dei Fori Imperiali... It's a shame, but we can be glad that some pictures and plans have survived, even if they aren't very accurate. I hope they do a better job now while constructing the subway 😄
                              Thanks for the column by the way, I'm sure it'll be useful.
                              • H Offline
                                Hepf
                                I am trying to figure out what Nero's Domus Transitoria might have looked like. I placed the two villas that I suppose were there at the time. Of the center one with the round room, only the part to the left is known by documents. The part to the right stepping down three levels is a supposition, but a rather logical one, if there were baths and a palestra (gym area) you expect also a residential area. It could only be in that direction, and that's on a steep slope, and a rather unstable one too. The villas almost link with the house of the Domitii, that is known by that crosslike hall, supposedly underground also at the time it was built and used (fresh hall in summer). So now I have to imagine what the above ground building might have looked like if, as is very probable, Nero bought the two villas and somehow welded the whole thing somehow ...
                                • H Offline
                                  Hepf
                                  Ok, Csaba won't agree, but I wanted to amuse myself some. I centered the whole building around the circular underground hall, the only known element, and I referred to some paintings from Pompei as a reference. So this is my version of the house of the Domitii as refurbished by Nero before the fire. The main point is that the whole thing happens on a hillside.
                                    Why would I not agree? Quite interesting concept! 😄
                                    (And though I do not always post/reply, I follow the topic closely)
                                    • F Offline
                                      fluffy82
                                      Looks interesting!
                                      Did you get your inspiration partly from the Esquiline wing of the Domus Aurea as well or is it just a coincidence?
                                      (the central square you have put over the remains of the so-called "House of the Domitii" reminds me of the pentagonal court, as well as the peristyle on the higher level; the Esquiline wing's first floor also had this pavilion like structure, according to Laura Fabbrini).
                                      I like the idea where Carandini puts a similar structure between the artificial lake and the vestibule, though I don't really agree with him placing the "coenatio rotunda" there...
                                      About the living quarters: there are many remains of neronian times below the Domus Flavia and Augustana. It is almost certain that Nero built a large reception hall where is now the Aula Regia, and the nymphaeum ("baths of Livia") could have been part of a triclinium, the same concept being reproduced on a larger scale by Domitian.
                                      Since the official part of Domitian's Palace is certainly based upon an older neronian lay-out, I like to think that the residential part was as well... Certainly because one of the walls I mentioned earlier, which is 2% out of axis with the rest of the palace, seems to built on foundations older than the rest of the palace, 1st century AD.
                                      I am still working on the late phase of the palace (severan/maxentian), once that is done I plan on doing the early flavian phase and have a shot at what the neronian phase could have been... But that's far future 😄
                                      • F Offline
                                        fluffy82
                                        Hey all,
                                        I thought I would post some pics of what I'm doing...
                                        I didn't render them yet, I prefer to wait until the model is more finished before I start putting textures etc.
                                        These are just most of the raw volumes (not quite finished) and the start of some deatils to the hippodrome.
                                        A simple lay-out for Augustus' home and the Temple/Precinct/Libraries of Apollo are there, the "Vigna Barberini" will follow after that.
                                        Don't hesitate to give comments, remarks, corrections, whatever! Always eager to learn... 😄
                                        Tom
                                        aerial view
                                        bird's eye over the Domus Augustana (private part)
                                        one of the fountains next to the Triclinium
                                        entrance to the Domus Augustana - I don't know yet if I'll make the porticus continuous like this, or interrupted
                                        overview of the hippodrome-garden
                                        the hemicycle
                                        view from one of the lower galeries in the hippodrome-garden
                                        • H Offline
                                          Hepf
                                          Ok, I am back. Fluffy's model is remarkable. I'd love to have it and stitch it with my work, it would spare me a lot of sweat.
                                          I am facing the problem of filling in the gaps, residentrial areas that we don't know much about, and must be somehow be filled with believable buildings. In some cases it's just a matter of putting in generic volumes and cubes, maybe with a roof. But in some cases I'd want to put in some believable buildings, as in the case of the road that goes towards the arch of Constantine. We know it was a straight road, about 11 meters wide, with sidewalks of maybe 4 m., lined with housings with shops at the floor level. I am making some meccano like thing, building blocks that can be assembled. I am posting one of such, and a pic of one of thousands of possible assemblies.
                                          domus_3.skp
                                            pichuneke
                                            Some time ago I thought that the Meccano/Lego way is the best for residential buildings.
                                            Rome Reborn does that using procedural software. And it's a pity that residential areas are not very well known, as far as I know Rome was the New York of that era, with "skyscrapers" (well, at least considering the time they were built).
                                            Meanwhile I am working with the spanish theatres of the XVII century, I hope I can come back soon with my roman models.
                                            And I am happy to see you again, hepf. I was wondering where were you. 😉
                                            • 11
                                            • 12
                                            • 9 / 12
