    Build Rome
    234 Posts 20 Posters 106.7k Views 20 Watching
    • H
      Hepf
      Hi Elysium,
      I visited Monumental Heart of Rome and I am impressed. Could have spared some work had I seen it before. Are you going on with it? Are you an archeologist too? And where from?
      • H
        Hepf
        Been working on the flavian situation of the Vigna Barberini. It has been much more messy than I thought. Working on two different axes is hell ...
        • S
          Sawduster
          Csaba,
          Thanks for posting that video. Don't think I've spent a more educational hour plus on SU than with that video.
          As an amateur enthusiast of Roman History, I've really enjoyed this whole thread and hope that it continues on. In my reading of Roman History, as well as historical fiction on the subject, I've always been amazed at the amount of razing of old buildings and replacement of them with new stuff. I guess the rubble of the razed stuff would tend to change the lay of the land, so to speak.
          May all your dimensions be the sum of their total.
          Jerry
          http://www.sawdustersplace.com
          • H
            Hepf
            Hi Sawduster,
            I'll try to go on with the thread, and thanks to Csaba's advice I am getting a bit more comfortable with SU.
            Don't think the romans where that whimsy. Their keyword was "renovatio", renewal. For an emperor, or any other important person, the renovation of a building of the past was much more important than building a new one. It connected him to a great name of the past, gave him status. So even if the old building was a shack, and the new one a marble palace, he would still claim he had renovated the old historical building. Buildings lasted centuries, with minor changes. The period from 64 aD and 80 aD was the great exception. In 64 the fire destroyed most of Rome. Nero rebuilt it anew, with new urban planning rules. With the rubble from the fire he elevated the ground in what is now the Coliseum square for about 4,5 meters, and created a lake at the center with its bottom at about the previous ground level. Then the Flavians came and tried to erase the memory of Nero, built the Coliseum and the rest. But even the Flavians kept most of Nero's architectures, renaming them and changing them here and there. And again what they built lasted for centuries, a lot of it is still there.
            • H
              Hepf
              This was the first Meta Sudans, the fountain that was destroyed by the fire of aD 64, about 6 meters below present floor level. A good amount of it was found during the excavations. The small templet at its side is a compitum. Only the base was found, so its elevation is a matter of speculation
              • H
                Hepf
                Tried my hand at Trajan's termae. Not quite satisfactory, but for the time being that's it.
                The problem I am facing is that, after speaking with a german researcher, he convinced me that what I posted as the Oppio wing of the Domus Aurea, is just the basis villae, and that the main building was on top and back, having being completely razed by Trajan when he built his termae. So I'll have to try my hand at a work of pure imagination, since practically no evidence exists of what this main building looked like ...
                traiano_p.skp
                • GaieusG
                  Looks cool to me.
                  As for imagination instead of facts - you need to decide what you want to do. Reconstruct or visualize (and give a clue how it may have looked).
                  Maybe you could make some distinction between the "probable" and "possible" reconstructions with basic colours or something.
                  • H
                    Hepf
                    I've thought about that, but it's tricky. I think I'll end up by making several projects, and some animations, mixing SU and Poser, maybe Bryce or Kerkithea, inserting some photo and movie scenes of the real thing and excavations etc.
                    I attach my first try at a sequence, it will get much more complex as it goes. Any advice welcome.
                    One thing. Is there a way to color lines, or that's possible only for faces?
                    And is there a way to freeze the project, so that who looks at it can change scenes, zoom pan and rotate, but not modify or edit the objects?
                    Thanks again
                    scene.skp
                    • GaieusG
                      Window > Styles > In model (the small house icon) > Edit > Edge settings > Color (at the bottom) > Color by material
                      Not in SketchUp. There are third party apps you can export the model - like 3DVIA for instance. Then people can see it online. There you can define if others can download your model (i.e. get access to the model itself) or it is only for viewing.
                      • H
                        Hepf
                        Thanks, Csaba. The hint on the lines was very useful. For the other thing, I found that there is a free SU viewer, that is exactly what I was looking for. Very user friendly browser that doesn't allow the user to access or alter the model.
                        I attach my experiment in architectural imagination. Opinions are welcome and sought for. The two forward branches are real, or at least the french of the academy thought so, there are some evidences from the excavations too. And the large pond at the back of the basis villae is real too. All the rest, the main building, is an invention, no evidences exist. For the round towers I took some ideas from Krause's reconstruction of Villa Jovis, in Capri ...
                        • GaieusG
                          Definitely looks good - only be extra careful with any additional, "imaginary" stuff. That can be the most questionable part of the whole reconstruction and you can get the most critiques on those.
                          • E
                            ELYSIUM
                            Hi Marco.
                            Your work is looking great!
                            How did your german friend convinced you that the main part of the villa was in the oppio hill?
                            There are some structures north of the bath that have the same orientation has the domus aurea, but i always thought it made more sense to think that the main building was in the palatine, and the recent find of the rotating room near the temple of heliogabalus seemed to confirm this. With the damnatio memoriae on Nero, the first thing to be destroyed would be the heart of the Domus Aurea, and trying to further erase his memory the Flavian emperors, built the Domus Flavia over it. It seems more likely rather than the Domus Aurea being abandoned for 40 years until Trajan built his baths.
                            What do you think?
                            • H
                              Hepf
                              You are both right, but I didn't mean the overall main building, if there was one, but the main body of the Oppio wing. I arrived at the same conclusions as Elysium, and here is the result. The back line of the building is pretty certain, because there is another house of Nero's era across the street.
                              As for the rotating room, it has been placed everywhere, and I am not yet sure that what they found was the real one. It's an impressive find, but it's difficult to decide what it really is. What they say was proof of the existence of ball bearings is rubbish ...
                              • H
                                Hepf
                                Started with Titus's baths. Extruded Palladio's reconstruction, but some things are fishy. I think the whole thing is aligned with the rest of the Oppio wing, they were initially intended (probably) as Nero's private baths. Don't think they were that symmetrical, the slant on the right side doesn't make sense. And the front abutting on the lake shore (or later in front of the Amphiteater)must be rethought ...
                                • H
                                  Hepf
                                  Well, it's growing. Now I have to solve the connection between the termae and the lacus, and with the Via Labicana. I'll try a solution with an overpass, it's easy since the huge staircase allows for it, 12 meters of difference between the courtyard and street level. But maybe that's too modern ...
                                  • GaieusG
                                    Definitely gaining shape, please, keep posting! 👍
                                    • H
                                      Hepf
                                      This is what I had in mind for the connection. The main function is as struts, to keep the terrain with a 12 m. dislevel from falling over. The Via Labicana would go through the double arch overpass. Two lateral ramps go down to street level, and one goes on the overpass to the lake. Of course this is roofless, to show the pathways. Walls and roofs will monumentalize it.
                                      • P
                                        pichuneke
                                        I keep reading you (and enjoying). I don't have the time I had some years ago to get involved with you, but at least I can tell you that you are doing it very well 😄 😉
                                        Meanwhile I will continue with a little temple here, a theatre there... 😄
                                        Forgive my spanglish...
                                        • H
                                          Hepf
                                          Muchas gracias, Pichuneke. Pero te confieso que la cosa se està poniendo difìcil. Ya veremos.
                                          This is what I ended up with for the access to the Termae of Titus. And it took me a lot of work too ...
                                          • H
                                            Hepf
                                            Changed some details on the lakefront ...
                                            • 11
                                            • 12
                                            • 3 / 12
