    NPR with Painter
    16 Posts 13 Posters 2.1k Views 13 Watching
    • L
      Landie
      Here is a test painting I've done with Corel Painter. As before, I model in SU, render in Kerkythea, composite in Photopaint add the Add Life entourage and finish in Painter.
      This time I;ve used a coloured canvas and worked with an underpainting to add color shift and light emphasis accross the image.
      Does anyone else work with Painter ?
      http://www.smithdimes.co.uk
      • T
        tomsdesk
        Landie, these are wonderous!
        2.5D Trees & Shrubs!
        • PixeroP
          Pixero
          Very nice indeed. πŸ‘
          • T
            teofas
            get out of here!! this are awsome, i love this style zoom images is outstanding!!!congrats!!
            http://www.spazioarquitectura.com
            • F
              FoXar
              Love it, great NPR with a good feeling to it!
              Cheers
              • R
                Ross Macintosh
                Perfection!
                  Beautifull and relaxing! 😎
                  • shuraS
                    shura
                    These are some masterpieces, congratulations Landie! I think this is the first time I see Painter used here. Are you working with version 11? Is the watercolor renderer really that powerful as the videos are showing?
                    I am really looking at this software for some time now - the painterly effects are so different from what Pshop can do...
                    cheers
                    • L
                      Landie
                      Huge thanks everyone.. πŸ˜„
                      This technique has developed out of trying, and failing many times. I needed a workflow that was efficient, with an end result I felt was truely hand painted. Painter just does it for me.
                      you are using 5 different types of software to achieve this nice artistic result, how long did it take you?
                      Hi james. I can afford to be simpler with the modelling and quicker rendering, as the finished piece is loose on detail. Overall it took 2 long days.
                      Hi Shura. I'm still on Painter 10 and to be honest nearly all of the watercolor brushes are very hard work and I never touch them. The brushes I use are a mix of pastels / oil pastels / airbrushes / blenders / and pencil. The big secrets are, clone painting, texturing and coloring your paper, using a lot of layers and working the underpainting. I'll post a tutorial on my site when I get a chance. If you need any tips in the meantime just drop me a line....happy to help out.
                      • ken28875K
                        ken28875
                        wonderful renders, Landie. Love your style.
                        Best,
                        _KN
                        Follow Your Dreams.
                        • artysmediaA
                          artysmedia
                          I think I have to try to use Painter program to achieve the same style.
                          the result is very good β˜€
                          thanks for the tip πŸ‘
                          Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                          Blog: Artysmedia
                          • shuraS
                            shura
                            Some insight is always welcome, and as you can see here you get the SketchUp folks exited.
                            please keep us informed!
                            I always was a lazy painter and doubt that I will ever get results like yours. But with 3D apps I was the same before SU turned up and changed that. πŸ˜„
                            • michaliszissiouM
                              michaliszissiou
                              Landie
                              πŸ‘ πŸ‘ πŸ‘
                              I really love these. I also tested painter, its a great app. You dont really need a renderer for this, you know.
                              A workflow using SU raw export and corelpainter is almost an industry standard in matte painting.
                              • L
                                Landie
                                @michaliszissiou said:
                                Landie
                                πŸ‘ πŸ‘ πŸ‘
                                Thanks...I've never been talented enough to raw paint over a guide. I've always been amazed by matte artists. With this workflow the render from Kerkythea makes things a lot easier when using painter in clone mode.
                                • boofredlayB
                                  boofredlay
                                  Very nice work indeed. Thanks for sharing.
                                  • majidM
                                    majid
                                    πŸ‘ verry inspiring and interesting result
