πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
NPR with Painter
16 Posts 13 Posters 1.4k Views
    Landie
    Here is a test painting I've done with Corel Painter. As before, I model in SU, render in Kerkythea, composite in Photopaint add the Add Life entourage and finish in Painter.
    This time I;ve used a coloured canvas and worked with an underpainting to add color shift and light emphasis accross the image.
    Does anyone else work with Painter ?
    http://www.smithdimes.co.uk
      tomsdesk
      Landie, these are wonderous!
      2.5D Trees & Shrubs!
        Pixero
        Very nice indeed. πŸ‘
          teofas
          get out of here!! this are awsome, i love this style zoom images is outstanding!!!congrats!!
          http://www.spazioarquitectura.com
          • F Offline
            FoXar
            Love it, great NPR with a good feeling to it!
            Cheers
              Ross Macintosh
              Perfection!
                Beautifull and relaxing! 😎
                  shura
                  These are some masterpieces, congratulations Landie! I think this is the first time I see Painter used here. Are you working with version 11? Is the watercolor renderer really that powerful as the videos are showing?
                  I am really looking at this software for some time now - the painterly effects are so different from what Pshop can do...
                  cheers
                    Landie
                    Huge thanks everyone.. πŸ˜„
                    This technique has developed out of trying, and failing many times. I needed a workflow that was efficient, with an end result I felt was truely hand painted. Painter just does it for me.
                    you are using 5 different types of software to achieve this nice artistic result, how long did it take you?
                    Hi james. I can afford to be simpler with the modelling and quicker rendering, as the finished piece is loose on detail. Overall it took 2 long days.
                    Hi Shura. I'm still on Painter 10 and to be honest nearly all of the watercolor brushes are very hard work and I never touch them. The brushes I use are a mix of pastels / oil pastels / airbrushes / blenders / and pencil. The big secrets are, clone painting, texturing and coloring your paper, using a lot of layers and working the underpainting. I'll post a tutorial on my site when I get a chance. If you need any tips in the meantime just drop me a line....happy to help out.
                      ken28875
                      wonderful renders, Landie. Love your style.
                      Best,
                      _KN
                      Follow Your Dreams.
                        artysmedia
                        I think I have to try to use Painter program to achieve the same style.
                        the result is very good β˜€
                        thanks for the tip πŸ‘
                        Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                        Blog: Artysmedia
                          shura
                          Some insight is always welcome, and as you can see here you get the SketchUp folks exited.
                          please keep us informed!
                          I always was a lazy painter and doubt that I will ever get results like yours. But with 3D apps I was the same before SU turned up and changed that. πŸ˜„
                          • michaliszissiouM Offline
                            michaliszissiou
                            Landie
                            πŸ‘ πŸ‘ πŸ‘
                            I really love these. I also tested painter, its a great app. You dont really need a renderer for this, you know.
                            A workflow using SU raw export and corelpainter is almost an industry standard in matte painting.
                              Landie
                              @michaliszissiou said:
                              Landie
                              πŸ‘ πŸ‘ πŸ‘
                              Thanks...I've never been talented enough to raw paint over a guide. I've always been amazed by matte artists. With this workflow the render from Kerkythea makes things a lot easier when using painter in clone mode.
                              • boofredlayB Offline
                                boofredlay
                                Very nice work indeed. Thanks for sharing.
                                • majidM Offline
                                  majid
                                  πŸ‘ verry inspiring and interesting result
