    Win32 output debugging
    9 Posts 4 Posters 3.6k Views 4 Watching
      Jim
      An alternative way for debugging on Windows machines using Win32API.so.
      You need a system debug viewer running such as DebugView and output goes to the debugger window. Also,
      If the application has no debugger and the system debugger is not active, OutputDebugString does nothing.
      This could also be used with Al's trace ruby messages technique so instead of output going to files ,it goes to the debugger.
      Come to think of it, something like this should be part of the api.
      OutputDebugString = Win32API.new("kernel32.dll", "OutputDebugString", ['P'], 'V')
      def opd(s="\0")
          s = s.to_s + "\0"
          OutputDebugString.call(s)
      opd(Time.now)
        This is excellent! πŸ‘ πŸ‘
        Double Plus Good!
        • Chris FullmerC Offline
          How would I use this Jim? I add that code to a script while I'm writing it. And do do what with it? It just does everything on its own?
          All my Plugins I've written
            Jim
            In DebugView, you can clear the debugger window by outputting the string "DBGVIEWCLEAR"
            • tbdT Offline
              tbd
              Jim: are you working for Render Plus now ? πŸ˜‰
              SketchUp Ruby Consultant | Podium 1.x developer
              http://plugins.ro
                I think this thread should be sticky... or in the sticky thread...
                  Jim
                  It turns out this OutputDebugString example is straight out of the Pickaxe book.
                    class CL_rps_console < Sketchup::Console
                    Sketchup::Console ❓ ❓
                      Jim
                      Here's what I came up with. Just make sure it is alphabetically the first file in Plugins in order to capture the earliest output.
                      require 'Win32API'
                      class CL_rps_console < Sketchup;;Console
                          def write(smess="\0")
                              smess = smess.to_s + "\0"
                              OutputDebugString.call(smess)
                      # redefine standard output to our new class
                      $old_stdout = $stdout # in case you want to turn off traces
                      $stdout = CL_rps_console.new
                      $stderr = $stdout
                      puts "-" * 40
                      puts Time.now
                      puts "Starting SketchUp"
                      puts "-" * 40
