    To space or not to space ".add_circle[@entity[0]...."
    3 Posts 2 Posters 334 Views 2 Watching
    • honoluludesktopH
      honoluludesktop
      Why would no space as below between .add_circle[@entity[0].... error:
      group = @master_group.entities.add_circle[@entity[0], @entity[1], @entity[2]], @vector3, @entity[3]
      ,but be OK with space between .add_circle[@entity [0].... as below:
      group = @master_group.entities.add_circle [@entity[0], @entity[1], @entity[2]], @vector3, @entity[3]?
      Yet, isn't .add_face([@entity[0]..... as below recommended?
      group = @block_group.entities.add_face([@entity[0],@entity[1],@entity[2]],[@entity[3],@entity[4],@entity[5]],[@entity[6],@entity[7],@entity[8]],[@entity[9],@entity[10],@entity[11]])
      • thomthomT
        That is invalid syntax.
        You have a [ bracket right up to the method name.
        [ and ( is not the same. ( and ) close off the arguments you pass to a method, but they are optional - you can leave a space between the method name and the arguments.
        .method([val1,val2], argument2) OK
        .method [val1,val2], argument2 OK
        .method[val1,val2], argument2 Invalid!
        Personally I always wrap arguments in ( and ) as I find the code easier to read and less ambiguous.
        • honoluludesktopH
          honoluludesktop
          OK, thanks.
