    Help with grouping groups
    17 Posts 2 Posters 1.1k Views 2 Watching
    • honoluludesktopH Offline
      honoluludesktop
      I am trying to group other groups. So, the following to create an array of groups:
      group = @entities.add_group(new_group)
      @all_groups.push group
      The code below worked with edges and faces, but when written to group groups it fails at new_group = sel_ents[0].all_connected
      sel = @group_all
      sel_ents = sel.to_a
      first_entity = sel_ents[0]
      while sel_ents.length > 0
        if (sel_ents[0].is_a? Sketchup;;Group) and sel_ents[0] == first_entity
          sel_ents = sel_ents - new_group
          big_group = @entities.add_group(new_group)
        else
          sel_ents1 = sel_ents - [sel_ents[0]]
      model.commit_operation
        Groups doesn't have an .all_connected method.
        Is this geometry created by your script earlier? Or is it geometry modelled by the user which you want to group via your Ruby?
          honoluludesktop
          It's created by my script.
            When you create geometry while modelling you draw the geometry first, like a face, then group it.
            But, when you build geometry via the API, create the group first and then the geometry directly inside it.
              honoluludesktop
              OK, let me run with that for a while. Do you mean something like:
              group = entities.add_group group.add_line . . .
              Shoots its 3:30 am, I better go to bed, and get back to this tomorrow. Anything you can post to help me is appreciated. Good night:-)
                Yes, like that.
                  honoluludesktop
                  I think I get my problem. I am trying to use one procedure group1 = @entities.add_group(@selection) to create all my groups, and maybe I can't. If I can't, how do I create a different groupX where X is the times I come back to make a new group.
                    You lost me a bit..
                    there should be no limit to how many entities you can add to a group.
                      honoluludesktop
                      No that's not what I meant. How can the following proc_1 be called multiple times to create a different group each time its called? The following doesn't work, yes?
                      def main
                        aFile.each do |e|
                          proc_1
                          proc_1
                      def proc_1
                        That will create a different group.
                        This will also create new groups
                        group1 = @entities.add_group group1 = @entities.add_group group1 = @entities.add_group
                        All this is doing is setting group1 to refer to the new group you create each time you call .add_group
                          proc_1 does nothing.
                          def proc_1
                            group_1 = @entities.add_group
                            list_of_groups.push group_1
                          You're creating a group
                          then adding the reference to that group to a non-existent array list_of_groups
                          list_of_groups in main has no relationship with list_of_groups in proc_1.
                          Have you looked up in Ruby how arguments and return values work? And variable scope? It's some fundamental concepts to programming.
                          I was a about post an example of what you can do, but I'm not sure what you intend with the code.
                          You are reading a file, and for each line you want to add a group to a bigger group?
                          def main
                            aFile.each do |e|
                              sub_group = big_group.add_group()
                              # now you can add entities to the sub-group
                              sub_group.entities.add_face(...)
                              sub_group.entities.add_line(...)
                            honoluludesktop
                            Ok, so how are the different groups placed in a big_group? My attempt fails at the 6th lines.
                            def main
                              big_group = @entities.add_group #do I need?
                              aFile.each do |e|
                                proc_1
                                proc_1
                                big_group.add_group(list_of_groups)#fails?
                            def proc_1
                            The following works with all Sketchup::Entity except for Sketchup::Group
                            def main
                              aFile.each do |e|
                                proc_1
                                proc_1
                                #following works except for adding groups
                                @entities.add_group(list_of_groups)
                            def proc_1
                              honoluludesktop
                              I am reading a Cad file of entities, making SU entities from that list. Some of the entities are Cad blocks (a bunch of Cad entities), that I am trying to turn into SU Group(s)
                              I can insert and group, edges and faces, but not groups.
                                honoluludesktop
                                Well, I made it work in the web console, now back to the program.
                                ` model = Sketchup.active_model
                                entities = model.active_entities
                                master_group = []
                                point1 = Geom::Point3d.new(0,0,0)
                                point2 = Geom::Point3d.new(20,20,0)
                                point3 = Geom::Point3d.new(10,10,0)
                                point4 = Geom::Point3d.new(30,30,0)
                                point5 = Geom::Point3d.new(10,30,0)
                                line1 = entities.add_line point1,point2
                                group1 = entities.add_group line1
                                master_group.push group1
                                line2 = entities.add_line point3,point4
                                group2 = entities.add_group line2
                                master_group.push group2
                                line3 = entities.add_line point3,point5
                                master_group.push line3
                                entities.add_group(master_group)`
                                edit master_group, select group1
                                  When you model you draw face/line - then group.
                                  But when you build geometry with the API, make the group first and then add the geometry directly inside the group - instead of moving it afterwards which is prone to crashes.
                                  master_group = entities.add_group
                                  group1 = master_group.entities.add_group
                                  line1 = group1.entities.add_line(point1,point2)
                                  group2 = master_group.entities.add_group
                                  line2 = group1.entities.add_line(point3,point4)
                                  group3 = master_group.entities.add_group
                                  line3 = group3.entities.add_line(point3,point5)`
                                    honoluludesktop
                                    Yes, I read something about that in the API, but I thought that was a problem for SU versions prior to 8.0. Anyway, I wouldn't have been able to do it without your help, thanks.
                                      It is safer in any case - as you don't risk your edges/faces merging with stuff it should not merge with.
