    Underwater HDRI map
    10 Posts 5 Posters 1.5k Views 5 Watching
    • L
      liam887
      Anybody have a good underwater HDRI map I can use. I found a few but the quality was very poor.
      Model is still a WIP ignore the materials but it will be for this model. Im not sure if underwater HRDI maps have the same properties as regular ones but if anybody knows let me know asap thanks!
      VISIT MY ONLINE GALLERY
      • FrederikF
        Frederik
        The only underwater hdri-maps I know of are from Dosch Design...
        Not free but high res and looking really good... 😉
        Or perhaps you can contact Bläcker Photography...
        Cheers
        Kim Frederik
        • L
          liam887
          Thanks!
          I only need one so I cant justify spending £100 on a whole pack cant really afford it. I will contact Bläcker Photography see if I can have permission to use one of his images, fingers crossed the people im working for will have one but I wont know till monday.
          • olisheaO
            olishea
            panorama here:
            http://www.panoramas.dk/tulamben.html
            not high res but it may do the trick with reflections. you will have to replace background, it will look too blurry.
            could you share your model? or PM it to me, would be cool to have a go at rendering in twilight.....no worries if not
            oli
            • soloS
              solo
              Liam,
              If you share model I may be able to make you one in Vue. I have done a few underwater scenes in the past and Vue has a panorama render setting.
              http://www.solos-art.com
              • L
                liam887
                @olishea said:
                panorama here:
                Yeah no worries I will finish that one up tonight and email it to you. no that picture is too small my final renderings will be pretty big I imagine. Hopefully they will have one in the office I can use they have loads of photos.
                @solo said:
                Liam,
                Yeah same ill email them to you later, this sub model is only a test model so I could practice underwater lighting and test materials the actual submarine model I have been commissioned to make I will not start till monday but you can both have this one and see what you can do.
                Thanks for the helps!
                • soloS
                  solo
                  Try this, It's a Vue created one, clear water with light from above.
                  http://dl.dropbox.com/u/1129899/undersea.hdr
                  • olisheaO
                    olishea
                    solo that looks seriously cool!!
                    oli
                    • J
                      jpalm32
                      VUE is amazing for that.
                      • L
                        liam887
                        thanks man I havent had time to do any renders been too busy with the model but ill try it out hopefully this evening or tomorrow im sure it will be more than adequate thanks again.
