    Coplanar surface tolerance
    8 Posts 4 Posters 1.2k Views 4 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Is there a simple way to set the tolerance required for surfaces to be considered coplanar by SU?
        honoluludesktop
        Is there any way to do this?
        • Chris FullmerC Offline
          Nope, no way to change SU's tolerance for coplanar-ness. You can test to see if it is considered coplanar (Thom put a LOT of workin into figuring this out). Then if it is not coplanar, you can redraw your gemoetry so that it is? That sounds painful though. What is this for?
          All my Plugins I've written
            honoluludesktop
            Accommodating small differences sometimes found in the coordinate database of Cad entities when moved from one app to another. Guess I will pass πŸ™‚
              As Chris says, SU's tolerance is fixed.
              • AdamBA Offline
                AdamB
                Well if you know the fixed tolerance, an alternative approach is to scale up your model and then allow SU to do its coplanar stuff, then scale back down.
                Adam
                  πŸ’­
                    @thomthom said:
                    :idea:
                    +1 !
