Soften-Edges using by ruby
Assuming
ss=Sketchup.active_model.selection...defns=[] ss.grep(Sketchup;;ComponentInstance).each{|e|defns << e.definition} defns.uniq! defns.each{|defn| defn.entities.grep(Sketchup;;Edge).each{|e| if e.faces.length==2 e.soft=true e.smooth=true end } }or something similar...
@tig said:
Assuming
ss=Sketchup.active_model.selection...defns=[] > ss.grep(Sketchup;;ComponentInstance).each{|e|defns << e.definition} > defns.uniq! > defns.each{|defn| > defn.entities.grep(Sketchup;;Edge).each{|e| > if e.faces.length==2 > e.soft=true > e.smooth=true > end > } > }or something similar...
yes...it works
this will save me time, since i noticed that some components edges come back visible in my models, for unknown reason...
now with just one clic, the problem is solved
thank you
The unexpected reversion of smoothed edges to solid is a known bug.
Never save when in a edit session. Even an auto-save can trigger this, so never stay inside an edit session for longer than you need to...
Register LoginAdvertisement
