    Plugin w/o script in Plugins folder???
    14 Posts 6 Posters 1.1k Views 6 Watching
      draftomatic
      I've seen commercial SketchUp plugins that work (they even get registered as extensions in SU), but there are no scripts for that plugin within the "Google SketchUp 8/Plugins/" folder...
      How do they do this?
        What plugins?
        Possibly, they've misplaced themselves in the Tools folder. (which is meant to be only Google's tools)
        • Dan RathbunD Offline
          Dan Rathbun
          I'd like to see an official statement, to this effect. If it exists ...
          I'm not here much anymore.
            It doesn't say explicitly that Tools should not be used, but it does say explicitly that the Plugins folder is there plugins should reside: http://code.google.com/apis/sketchup/docs/loading.html
            • Chris FullmerC Offline
              Bryce (or John maybe?) also commented in the forums here, or the groups, or the old forums that the tools folder is supposed to be for their use, and we should only stick to the plugins folder.
              One reason that was given was that some of their files get upgraded between versions (sketchup.rb for example). And if it lived in the plugins folder, users commonly copy the contents of their plugin folder from the old version of SU to the new version of SU. This would overwrite the new sketchup.rb file with the old one. So splitting out their files into a "tools" folder solved this problem.
              I'm not sure if they had other reasons than that. And I'm not sure where this is written unfortunately (and it might even be completely lost as there were a few closed @last forums that are not publicly archived anywhere). But if I find a link, I'll post it. But then again, if its only a comment on a forum, does that really make it official? Seems like it should be documented somewhere a bit more formal...
              All my Plugins I've written
                I find it formal enough that the FAQ says explicitly to use the Plugins folder.
                  Fair enough, that does seem pretty straightforward.
                    draftomatic
                    @thomthom said:
                    What plugins?
                    The plugin was LightUp DEMO. And yea, I just checked... they put their stuff in Tools. πŸ˜ƒ
                    • AdamBA Offline
                      AdamB
                      Yes, LightUp lives in the Tools folder because right from the start I've always felt there is semantic distinction between a Plugin and a Tool.
                      So for me, a Tool is an additional icon in the Toolbar that can be selected by the user, and through a GUI, does "Stuff". A Plugin is something that extends the underlying data - typically with attributes. It 'decorates' the SketchUp model with metadata.
                      So in a perfect world, you have a bunch of Plugins that extend the underlying objects, and a Tool that operates on that data.
                      The idea that Google plugins are called Tools and our plugins are called Plugins strikes me as kinda silly.
                      Just my 2 of your Earth cents worth... πŸ˜‰
                      • honoluludesktopH Offline
                        honoluludesktop
                        AdamB, What happens to your files when SU is uninsulated? Typically my plugins and certain folders survive. Does LightUp too remain?
                          Then most Ruby plugins for SU should have been in the Tools folder.
                          And it just complicates things by having multiple places to put stuff.
                            Dan Rathbun
                            All this "seems" at first glance to make sense... however Google themselves broke this "informal" rule.
                            They have installed the Ocean, Utilities and Examples extensions in the Plugins folder. Ocean at least was updated for v8, but many people out there have likely overwritten it, by copying the v7 files over to v8 Plugins folder. (You won't see big problems as these are not used that much.)
                            I kindof agree with Adam ... a Tool is a subtype of Plugin, that is used by the user in an interactive way to create or edit model geometry. A Report generator, or an Import or Export Utility is not a Tool, although you might say they are a subtype of Extension or Plugin.
                            So other catagories:
                            Utilites into which I'd put things like: Smustard Organizer and TBD's SUbridge.
                            Libraries which are used by many Plugins, Extensions, Utilities or Tools.
                            One of the reasons to put things in the Tools folder, is some plugins (like Organizer,) can change files. So putting important Library like rubies in the Tools folder is a way to keep them separate from the run of the mill plugins. This is really a temporary fix, until we have control over the number and order of "autoload" folders. I'd really like a dedicated "Lib" folder.
                              Dan Rathbun
                              This is from a developer point of view.
                              Extension
                                 +-- Plugin (things the users SEE, KNOW about, and USE.)
                                 |     +--- Tool (User interacts with *manually*, to create/edit model objects.)
                                 |     |       +--- GUI Tools (like on the DRAW and TOOLS menu.)
                                 |     |       +--- Wizard Tools (DC Attribute Editor, RoofGenerator, etc.)
                                 |     +--- Implement (User uses on occasion for *specific* tasks.)
                                 |     |       +--- BuildingMaker
                                 |     |       +--- Exporter
                                 |     |       +--- Importer
                                 |     |       +--- Renderers
                                 |     +--- Utility (User uses on occasion; for *more general/useful* tasks.)
                                 |             +--- Backup Manager
                                 |             +--- Console (... including custom Console Extensions.)
                                 |             +--- IO Bridge (.. like SU Bridge by TBD.)
                                 |             +--- Plugin Installer/Updater/Manager
                                 +-- Library
                                 |     +--- API (The Sketchup API *itself* is a Ruby Extension!)
                                 |     |     +--- DynamicComponents class (also creates both GUI and Wizard Tools)
                                 |     |     +--- Mixin module community Library
                                 |     |     +--- SKX extensions (if we ever get it released!)
                                 |     |     +--- TT_Lib & TT_Lib2 (ThomThom; Library extensions.)
                                 |     +--- Ruby
                                 |           +--- Standard Library extensions (ie; socket.so, matrix.rb, etc.)
                                 |           +--- win32-api Library extensions (Dan Berger; replacement for Win32API.so)
                                 +-- Service (... things the user never sees, that operate transparently.)
                                       +--- Socket Communications
                                       +--- Smustard Organizer
                                Dan Rathbun
                                The diagram (previous post,) was prompted by yet another argument over what was a Tool, and what was a Utility, whether they were Plugins or Extensions, or both.
                                My argument is that everything loaded into Ruby (except the Core,) is an Extension.
                                Then 3 main types: Plugin, Library and Service.
                                Although I show 3 "kinds" of Plugins, in reality there is often overlap. A given plugin may have several, (if not all,) subtypes as features.
