    Toolbar problem in SU 8 on Windows
    27 Posts 4 Posters 3.3k Views 4 Watching
    • Dan RathbunD
      Dan Rathbun
      Very strange... Al you may want to see if a plugin overrode UI.start_timer, by dumping a methos list: UI.methods.sort
      look for a "old_start_timer etc.
      Or set $VERBOSE=trueand open the console before anyother rubies load.
      When a method gets overriden, Ruby issues a warning to the console.
      You can use a script snippet I posted: http://forums.sketchucation.com/viewtopic.php?f=180&t=30539#p269522
      I'm not here much anymore.
      • thomthomT
        I'm also seeing warnings like Al reports.
        • Dan RathbunD
          Dan Rathbun
          Well then maybe you both dump a plugins Dir listing and compare.
          I have Google Tools: DCs, Sandbox, SolarNorth, and Photo(Web)Textures loaded.
          3rd party Plugins: only Fredo's BezierSpline1.4, Smustard Organizer and my ver2ofOceanModeling.
          ( It occurs to me that you guys might not have the correct Win32API.so file for v1.8.6-p287,
          I remember having some problems with and old copy of Win32API.so, when I first started using v1.8.6 with SU7. )
          Here's the 2 so files distro'd with v1.8.6-p287:
          v186_p287_so.zip
          • Dan RathbunD
            Dan Rathbun
            On XP or Vista ??
            • thomthomT
              Windows7
              • Dan RathbunD
                Dan Rathbun
                @al hart said:
                The timer did not help. Thanks for the idea, Dan.
                Has anyone tried my code (You do not actually need any .PNG files) and/or does anyone have a small .rb which I can load from a directory, rather than putting in plugins to see what it does?
                Latest code:
                >  toolbar = UI;;Toolbar.new "Test2"
                >  # This toolbar icon simply displays TestX on the screen
                >  cmd = UI;;Command.new("Test2") {
                >    UI.messagebox "Test2"
                >  cmd.small_icon = "ToolPencilSmall.png"
                >  cmd.large_icon = "ToolPencilLarge.png"
                >  cmd.tooltip = "Test Toolbars"
                >  cmd.status_bar_text = "Testing the toolbars class"
                >  cmd.menu_text = "Test2"
                >  toolbar = toolbar.add_item cmd
                >  cmd = UI;;Command.new("Test3") {
                >    UI.messagebox "Test3"
                >  cmd.menu_text = "Test3"
                >  toolbar.show
                >   # Show toolbar if it was open when we shutdown.
                >   state = toolbar.get_last_state
                > printf("toolar state; %s\n", state)
                >   if (state == TB_VISIBLE)
                >     toolbar.restore
                >     # Per bug 2902434, adding a timer call to restore the toolbar. This
                >     # fixes a toolbar resizing regression on PC as the restore() call
                >     # does not seem to work as the script is first loading.
                > printf("Starting timer\n")
                >     UI.start_timer(0.1, false) {
                >       toolbar.restore
                > printf("After Starting timer\n")
                >   end
                Just noticed a few boo-boos when rereading this old post.
                (1) The statement toolbar.show (on line 22 of the snippet,) defeats the state/restore block that follows.
                (2) The state/restore conditional block would only work on the second toolbar "Test3" (otherwise you need a state/restore block after defining each toolbar, if you are going to keep reusing the same reference, in this case the identifier toolbar.)
                My latest recommended snippet is in this post:
                Re: How to use the toolbar.show method
                ******* You could wrap the snippet in a method block called:
                toolbar_restore(toolbar)
                and then pass each toolbar reference to the method after creation, so as to make your code more "clean". (Also vars delay and state will be local to the method and get cleaned up automatically.)
                • Al HartA
                  Al Hart
                  We are still struggling with Toolbars in SU8.
                  Our biggest remaining problem, is that that when we load a plugin by hand, rather than having it loaded automatically as SketchUp loads - (we offer both options to users - always load the app, or manually load it from the Plugins menu) - the toolbar appears - but is not docked.
                  I looked at your code snippet in the other thread, but it is hard to figure out how to put everything together.
                  Can you, (or someone), provide a .RB which I can execute manually, (not placing it in the plugins folder - but loading the .RB from the ruby console - or later from the Plugins menu), which creates a new toolbar, and docks it properly?
                  Then I can grab from it what I need, etc. to get it to work with our app.
                  Al Hart
                  http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
                  IRender nXt from Render Plus
                  • 2 / 2
