    No Syntax Errors on Loading?
    9 Posts 3 Posters 781 Views 3 Watching
      Jim
      @jim said:
      I was feeling left out, so I added a loaderr.rb file to Plugins, and filled in with nonsense, but I didn't get a load error. 😞
      SketchUp 8 does not display the Load Error dialog for scripts that have syntax errors, as version 7 does.
        SU8?
          Jim
          Yes, version 8 displays no errors, while version 7 shows an error dialog on the same file.
            That's no good. Makes it very hard to debug startup errors.
            Do you get output of you use the command argument to route it to file?
            • Dan RathbunD Offline
              Dan Rathbun
              What kind of nonsense ??
              Others are reporting the Load Error dialog for when files cannot be found by require and for method first argument syntax errors.
              I'm not here much anymore.
                Jim
                No output is generated at all using a command-line: Sketchup.exe > log.txt 2>&1. But I still think this is better than stopping SketchUp dead with a model Load Error dialog like in version 7.
                You can still see any errors by loading the file using the Ruby Console. But it might be nice to see the errors in the redirected log.txt file.
                  Dan Rathbun
                  And what if the very first file to load !!!aaa.rb opens the Ruby Console and waits a half sec, before letting the load process continue ??
                    Jim
                    I don't know, what happens? (because I'm not sure how to go about doing that.)
                    And let me thank Sketchup for fixing those "freeCommand" lines in the output.
                      Dan Rathbun
                      here is a simple file that should load before all others:
                      call it !!!aaa.rb
                      # file; !!!aaa.rb
                      # A snippet from my !loadpaths.rb - by Dan Rathbun
                      skp_info=true
                      ruby_info=true
                      load_paths=true
                      global_vars=false
                      delay=0.5
                      Sketchup.send_action("showRubyPanel;")
                          UI.start_timer(delay,false) {
                            puts "\n"
                            puts '----------------------------------------------------'<<"\n"
                            if skp_info
                              # print Sketchup Info to console
                              puts ' Sketchup has been Loaded...'<<"\n"
                              puts ' Sketchup Version  ; '<<"#{Sketchup.version}\n"
                            if ruby_info
                              # print Ruby Info to console
                              puts ' RUBY has been Loaded...'<<"\n"
                              puts ' RUBY_PLATFORM     ; '<<"#{RUBY_PLATFORM}\n"
                              puts ' RUBY_VERSION      ; '<<"#{RUBY_VERSION}"
                              puts ' RUBY_PATCHLEVEL   ; '<<"#{RUBY_PATCHLEVEL}"
                              puts ' RUBY_RELEASE_DATE ; '<<"#{RUBY_RELEASE_DATE}"
                              puts ' RUBY_COPYRIGHT    ; '<<"#{RUBY_COPYRIGHT}\n"
                            end # ruby_info
                            if load_paths
                              # print LOAD PATHS to console
                              puts "\n LOAD PATHS ($LOAD_PATH | aka $;) array;\n"
                              $LOAD_PATH.each {|x| puts " #{x}\n"}
                            end # load_paths
                            if global_vars
                              # print Global variables to console
                              puts ' RUBY Global variables;'<<"\n"
                              global_variables.each {|x| puts " #{x} = "<<eval("#{x}.inspect"<<"\n")}
                            end # global_vars
                            puts '----------------------------------------------------'<<"\n\n"
