    Moldings, Casing Etc.
    8 Posts 8 Posters 3.0k Views 8 Watching
      Sawduster
      Don't know if I should post this here or in Materials or someplace else, so if the mods want to move it, go ahead.
      Some of you may have these, since they've been around a while, but others may not have seen them. They are profiles of molds, casing, bar rail, . . . and I find them handy. I open the file in SU, find what I'm looking for, select it, [CTRL][C] then [CTRL][V] them into the model I'm working on. They come in as components, so handle that as you need to for your purpose, but the first thing I do is open it for editing, use the tape tool to measure the base, then resize to the size I need, say 1 1/4". I can either explode and extrude around a drawer front or what ever, or open it in component edit and push/pull the molding out to the length I need for an onlayed molding.
      Anyway, here they are. A couple are zipped because they're pretty large.
      astragalsV5.skp
      bar_rails.skp
      basecapsV5.skp
      baseshoesV5.skp
      casingsV5.zip
      chairrailsV5.skp
      handrailsV5.skp
      crownV5.zip
      picturerailsV5.skp
      May all your dimensions be the sum of their total.
      Jerry
      http://www.sawdustersplace.com
      • U Offline
        unacom
        Thanks, excellent collection. Helped me
          Jim
          Thanks, quite a collection.
            Robert
            Thanks!
              It is quite a collection. It's too bad all the curves have been exploded.
                lapx
                Thanks! This will come in handy, coupled with the profile builder ruby script
                • RonSR Offline
                  RonS
                  Here is the original post with the curves welded.
                  http://forums.sketchucation.com/viewtopic.php?t=3001
                  Design is not just what it looks like and feels like. Design is how it works.
                  Steve Jobs
                  RonS
                    mics_54
                    Thanks! πŸ‘
