    [Plugin] Spherical Spiral (Archimedes)
    4 Posts 3 Posters 8.4k Views 3 Watching
    • R
      Regular Polygon
      Here is another simple to use plugin for geometry creation. The spiral is a 3D curve that wraps around the surface of a sphere, going from pole to pole. Specifically, this is an Archimedean spherical spiral because, like the 2D Archimedean spiral, the turns are all the same distance apart.
      To activate, select Draw -> Spherical Spiral (Archimedes). Enter the parameters in the dialog box, and the spherical spiral is created as a component that you can place in the model.
      It looks better if you give the spiral curve some substance using a plugin like Tube Along Path.
      The Spherical Spiral is at: regularpolygon.org/plugins/spherical-spiral.php.
      My SketchUp Plugins
        Ah damned too late for these posts and following ๐Ÿ˜„
        • R
          Regular Polygon
          They were drawing spirals on a torus, so this wouldn't really help, right? ๐Ÿ˜•
          But I was thinking, that would be another good plugin. One that draws a spiral on a torus. The spiral can revolve around two directions, the "big circle" and the "little circle." A simple plugin would allow you to enter the number of revolutions in each direction and then draw the spiral. ๐Ÿ’ญ
          My SketchUp Plugins
          • mitcorbM
            mitcorb
            @Regular Polygon:
            Thank you for your efforts. These rubies you have done will be very useful.
