    Sketchup and a winder staircase
    3 Posts 3 Posters 3.0k Views 3 Watching
    • G
      Gene Davis
      For a set of house plans I am finishing for a client, the staircase is to be included in details. I did the model of the stairs in SU, and have detailed the parts with dimensioned layout drawings for each. A look at the stairs, and a screencap from one of the drawings, is attached.
      If you have done this for stairs, please show me your method and results, if you can. I am interested in simplifying this process however possible. Thanks.
      • W
        wootton
        I've done stairs with landings, but no winders. Screencaps look nicely done, but it's hard to tell about process without the skp file. I did learn one trick about drawing stairs: draw a vertical line from floor to floor, then divide into segments equal to the number of risers. This gives a "story pole" for constructing the treads at the correct height.
        Tom Wootton
        • M
          mut
          Hey, I do stairs all the time, heres a link to one of mine, no joinery modeled though, just the overview of the staircase
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          http://www.StairBox.com We make stairs... easy
