    ComponentDefinition.instances strange behavior. Bug?
    3 Posts 2 Posters 465 Views 2 Watching
    • V
      Viskiz
      I have two ComponentDefinitions (d1 and d2) in model. Each of them has one instance. Strange thing begins, when I make a new Component of the both instances and then explode it. Then d1 and d2 instances returns me array of length 2.
      d1.instances -> #[#Sketchup::ComponentInstance:0x6ba89c4]
      d2.instances -> #[#Sketchup::ComponentInstance:0x9bc96e4]
      Using mouse I select both instances, make Component of them and explode it.
      d1.instances -> [#Sketchup::ComponentInstance:0x6ba89c4, #Sketchup::ComponentInstance:0x9bc2164]
      d2.instances -> [#Sketchup::ComponentInstance:0x9bc96e4, #Sketchup::ComponentInstance:0x9bc1fd4]
      but there is no any new instances in model, outliner does not show them too. Is it a bug or I misunderstand something? Maybe there is some purge function for d.instances or something?
      • thomthomT
        Because after exploding you have instances in your model and in the definition of the instance you just exploded. Remember that definitions doesn't disappear when they are unused - you need to purge them.
        • V
          Viskiz
          Thanks!
